Beogram 4000
Not Answered This post has 0 verified answers | 5 Replies | 1 Follower
Jeffq
Jeffq posted on Thu, Dec 3 2020 10:33 AM
Does anyone know if the  sensor arm Photo resistor is still available, and if so where can they be obtained, a leg has broken off mine and I need to replace it, failing this does anyone know  the specification of the photo resistor (OPH1) so I can try and find a suitable find a replacement
Craig
Yarm, United Kingdom
Silver Member
Craig replied on Thu, Dec 3 2020 12:57 PM
I have replaced a broken sensor with an OSRAM component....
A Beogram 4000 - (beoworld.org)
Craig
Silver Member
Craig replied on Thu, Dec 3 2020 1:07 PM
Osram Opto, SFH 206 K IR
I think it was this one..........
sonavor
Texas, United States
Alain ("boneofiel") on the Beolover Blog used an OSRAM LPT 80A with success as well.
-sonavor
Jeffq
Jeffq replied on Thu, Dec 3 2020 2:54 PM
Great, thanks, the manual shows it as an LDR as opposed to a photo diode but these are relatively cheap so certainly worth giving a go
sonavor
Alain's blog post gives a detailed look at the original circuit and his replacement. It's good information whether you use his solution or not.
-sonavor
Page 1 of 1 (6 items) | RSS
