I'm very taken with the BL18's and was considering upgrading from my old trusty BL6000.
Problem is my local B&O store is has been closed for some time so its a bit difficult to road test them!
I would be grateful for peoples opinion if they own the 18's.
I'm aware they would sound better but in peoples opinions is it worth the upgrade?
Any help would be gratefully appreciated.
TIA Mark
New: Beovision Harmony, Beolab 50's, Beolab 18's, Beolab 17's, Beolab 3's, Beosound 9000 mk3, Beosound Stage & LG, Beosound 2, Beoplay M3, Beoplay A1, Beoplay H4 gen 2, Beoplay E8 3.0
mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Old: Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
I own BL 6000s a d BL 8002 and my neighbor across from me has a BL18. There is a huge difference between BL 18 and both BL 6000 and BL 8002s. Not even close IMHO.
B&O in my life 😊:
Plumber, not to steer your inquiry too off course but, firstly, yes, I love my BL18s. They’re drop dead gorgeous and the clarity is outstanding. I love them.
That said... perhaps consider BL17 on stands... the low-end is unreal for the size. Far better than BL18. Yes, they’re not as pretty but many here feel they sound better than BL18 overall. Watch John from B&O Manchester’s review on them on YouTube.
Not sure how much aesthetics matters to you but if you’re open minded, perhaps consider BL17, too. But let’s be honest, you can’t go wrong either way!
Currently: BeoLab 17, BeoLab 18, BeoSound Core, BeoPlay S8 Connection Hub, Essence Remote
Previously: BeoSound 1 non-GVA
Hi Curly.
your set up is BL17 e BL18 connetted to the core ? everything works fine?
thanks for your answer
I only have one stereo pair of speakers connected to my Core at a time. Currently, my BL18 are in storage in their original packaging. I am currently using my BL17 connected to my Core and it works great.
Thanks for the input all.
Cheers Mark
I could be interested yes.
Where abouts in the UK are you?
London (NW)
plumber77: I could be interested yes. Where abouts in the UK are you?
Have you a price in mind?
What cabinet and fret type is it?
Sorry I can't find the private message section
email me if you like
sandeepbhatia@me.com
plumber77: Have you a price in mind? What cabinet and fret type is it? Sorry I can't find the private message section
