hooking my mac up to an MX6000
Answered (Not Verified) This post has 0 verified answers | 1 Reply | 3 Followers
mx6000lover
mx6000lover posted on Wed, Jan 23 2013 12:19 PM
Hello there
I own a venerable MX6000 that I am trying to hook up to my Macbook pro so I can watch films etc.
I have bought an HDMI - SCART converter, and plugged it all in, but the picture on the screen is jumping about.
What am I doing wrong?
Ben
Stoobietoo
Exeter, Devon, UK
Suggested by Stoobietoo
I'm not familliar with the Macbook Pro, but are there any settings where you can go in and change the settings to make sure it is outputting the correct signal.
For example, if your TV is a UK model you need it to be set to PAL (a US model will need to be set to NTSC).
The AppleTV I have (similar software to Mac OS) is connected to a scart socket and once it was set for PAL, I had to chose from a list of outputs - 1080p, 1080i, 720p, 576p & 480p to make it work.
You might need to experiment!
Stoobie
Page 1 of 1 (2 items) | RSS
