Bang & Olufsen App 3.8
Not Answered This post has 0 verified answers | 38 Replies | 3 Followers
MrAndersen
MrAndersen posted on Mon, Nov 9 2020 10:40 AM
Hi all
New beta is out with a configurable widget for controlling your setup. Touch to join, Beosound Shape sound modes and other options. We no longer open the app, but send the command directly from the widget, based on your feedback this was what you were looking for. You will find the configuration here settings->widget, please let us know what other features you would like to see here. Furthermore, we have released a radio service for the Beosound Balance, you can now assign radio stations to the favorite buttons without using Google.
Best regards
Thomas, Bang & Olufsen
Jaffrey2230
Washington DC
Silver Member
Just curious why the Core does not have a product image when it is a current product. The A6 for instance isn't sold anymore and yet has an image.
B&O in my life 😊:
  • Beolab 8002 + Beolab 2 + Beosound Core with Essence Remote (Office)
  • Beolab 6000 + Beolab 11 + Beosound Core with Essence Remote (Bedroom)
  • Beoplay A9 Mk2 (Living Room)
  • Beosound 1 with wireless dock (Portable)
  • Beosound Balance (Dining)
  • Beoplay H95 (Focused listening, travel)
  • Beoplay H9 (3rd gen) (retired)
  • Beoplay P6 (Portable)
  • Beotime wall clock (hallway entrance)
  • BMW X5 50i with B&O Audio Package (Commute/drive)
Jaffrey2230
Washington DC
Silver Member
The App overall works well for all my products I added to the widget. I like that you can exclude some products from the widget. Overall definitely a progress.
B&O in my life 😊:
1990
1990 replied on Tue, Nov 10 2020 6:11 AM
Took a bit to set the widget up, but when done it works perfectly. Very useful to be able to join from the iPhone!
laseralex
The new Widget is a great step in the right direction.  I appreciate that B&O is trying to improve their app and is soliciting feedback from their fanbase and heaviest users.
Here is my feedback:
I'd like to start with agreeing with what mbolo01 said about icons using instead of text to indicate join multiroom versus settings.  That would be a huge improvement.  His proposed illustration shows B&O product names like M3, M5, BS1, but those should definitely be the product name entered in the app, as I would otherwise not know which M5 or Essence I was controlling.
For some reason the Touch to Join function is not working for me - when I touch the "join" button it flashes red but no join action happens.  I've tried with both the Moment in my office and the Essence in my kitchen as sources, trying to add the living room or master bedroom essences.  The top button of the Essence Remote does work for touch-to-join when the widget fails; the Halo in the kitchen also joins as expected with the join icon.
I would like to also to echo mbolo01's comment about the lack of "Touch to Join" functionality for the Moment.  I know the Moment is discontinued and support is minimal ( Angry ), but it shouldn't be difficult to get this function working in the widget since I can do it in the app.
Sources: 2x Beosound Moment • 4x Beosound Essence Mk II
Speakers: 3x Beolab 8000 • 1x Beolab 6000 • 1x Beolab 3 • 3x Beolab 2 • 4x BeoPlay M5 • 1x BeoPlay A6
Control:  9x Essence Remote  • 1x Beoremote Halo
mbolo01
Annecy - France
ONLINE
laseralex:
Thanks for supporting my comments!
The product names shown in the image are effectively the ones I entered in the App, so it is ok for you.
FYI: I had to use short product names with no other possible meaning such kitchen or living room to ease voice controlled home automation
Seanie_230
UK
Took me a few to figure it out but works well.
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
seethroughyou
UK
Will they ever incorporate volume control functionality in one place?
At present I have to leave the Core, open BL90 to change volume and the exit and go into Core. Very tiresome.
ngnear
ngnear replied on Wed, Nov 11 2020 4:53 AM
seethroughyou:
Switching from one device to another takes just 2 taps.
Tim
Tap on the device name
List of devices appears. Tap on the one required.
mbolo01
Annecy - France
ONLINE
I find the Widgets icons a little bit big on an iPad
mbolo01
Annecy - France
ONLINE
@MrAndersen: is there still a beta program?
Production version is now:
And the latest beta:
Quite significant version difference isn’t it?
seethroughyou
UK
Yes 2 taps when going from current track being played to the BL90 volume page. Stupid and tedious. So counter to old B&O way of doing things. Then you have reverse and tap twice to go current track. Four taps. Sort it out. B&O - Stop being lazy and make it happen. So obvious a deficit.
MrAndersen
Hi mbolo01
This was a fix of some crashes we observed in the market. We made what we called a hotfix, with some very small fixes. For some reason the Apple review time is much longer for test flight than with a normal release. Hence, in these situations where I put them into review at the same time, the official version will be out first. You should have it by now.
Br
Thomas
mbolo01
Annecy - France
ONLINE
MrAndersen:
Got you thanks.
I’ll take this parameter into consideration when it happens next.
mbolo01
Annecy - France
ONLINE
mbolo01 replied on Thu, Dec 17 2020 11:50 AM
I would have given more space between the WiFi and the Multiroom icon, and I would have set the same tint for both
Dyssegaard
Copenhagen, Denmark
Silver Member
mbolo01:
I agree with you about the spacing and tint.
Further more I wonder why there are WiFi symbols on my multi room products as they are all cabled to my network?
The Bluetooth icons only shows when the product is connected - so that is ok.
Best regards - Dyssegaard
Living room: Beovision Eclipse 55, Beolab 3 / R1 (back), Beolab 2 / R1 (sub), AppleTV 4K. Bedroom: Beovision 11-40, AppleTV 4. Home office: Beoplay M5. Kitchen: Beoplay M5. Travel: Beoplay H8, Beoplay A1. NAS: WD My Cloud Home / Plex DLNA Server.
Page 2 of 3 (39 items) < Previous 1 2 3 Next > | RSS
