BeoSound SoundCenter and wallmounted TV separately?
Not Answered This post has 0 verified answers | 10 Replies | 1 Follower
Michael
Sweden
Michael posted on Mon, Nov 2 2020 4:18 PM
Hello,
Has anyone here done an install with a BeoSound SoundCenter and a TV separately from each other? Like a wall mounted SoundCenter + a wall mounted TV a bit above?
I am curious about if it can be made in a nice way so that the mounting for a TV is concealed. Reason for this is to be able to use a bigger monitor with a smaller SoundCenter as the wall won't allow for a wider than the 55" model Sound Center.
flatwhite
I have done precisely this with a Eclipse 55 SoundCenter with a LG C9 65 on top. Main challenge is to attach the soundcenter to the wall without the original 600EUR wall bracket.
Michael
Sweden
flatwhite:
How did you hide the mounting part on the top of the sound center?
Do you have a photo of the end result?
flatwhite
flatwhite
See my original post. Will upload new pictures shortly.
https://forum.beoworld.org/forums/p/42604/310808.aspx#310808
Michael
Sweden
Thanks, looks doable. I wanted to separate the two more however. But might be easier to just stay with the standard solution.
flatwhite
If you separate the two you will either see your ugly bracket in the middle, or the long metal panel on the left side with the original bracket.
https://www.avensyshome.co.uk/p-90011-bang-olufsen-beovision-eclipse-motorised-wall-bracket.aspx
Michael
Sweden
I guess it could be hidden with a 3D printed insert and a removed stand from the sound center. It seem affixed with a few screws only.
flatwhite
Would love to see that.
Another, expensive option would be the STB close wall bracket https://www.stbbrackets.co.uk/en-GB/product/BeoVision-Eclipse/BeoVision-Eclipse-Close-Wall-Bracket
Austin
United States
ONLINE
So from a software standpoint, you just download the B&O app, connect the SC and TV via ethernet cable and all surround sounds and beoremote one work to control the TV and SC?
flatwhite
Yes.
Page 1 of 1 (11 items) | RSS
