Have I missed something, or has this new TV already been discussed somewhere?
BV Eclipse 55 Brass - BL 18 Brass - BL 19 Brass - BL17 Black - BL 3 White - BS Moment - BS 2 Brass - BV Horizon 48 - BS3000 - BS 3200 - BS Essence MK2 - BL 4000 - V1 40 Black - V1 40 White - BLC NL/ML - H6 - H4 - E8 Motion - A8 Earphone - Beolit 12 - Beolit 15 - Beoplay A1 Green - Beoplay A3 White
steve1977:Also, i can live without a b&o as long as it doesn’t start with an LG logo and doesn’t display the LG logo in the UI.
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Library: A6, Beocom 6000 Bedroom: M5 Office: Beocom 2 Travel: Beoplay E8 2.0, Beoplay P2
steve1977:Sounds good! I wouldn’t mind to adjust through the app. Also, i can live without a b&o as long as it doesn’t start with an LG logo and doesn’t display the LG logo in the UI. I’m getting closer to the purchase ;)
Cant say on the Contour, but I have the new Eclipse ver. 2, and there is no logo at all when starting up. No B&O, no LG.
- duplicate -
Hiort:But it does show LG logos, right?
The TV is an LG, it comes in a LG box. It is exactly the same TV you buy in Currys/Walmart (select your own budget Electrical retailer) - why would it start up with a B&O Logo?
Ban boring signatures!
Duplicate
Puncher: The TV is an LG, it comes in a LG box. It is exactly the same TV you buy in Currys/Walmart (select your own budget Electrical retailer) - why would it start up with a B&O Logo?
It's literally an LG CX in a frame with a Stage. Nothing more, nothing less. No integration at all. No different from my LG GX + Stage combination!
Also, you don't get obvious LG logos or similar even on the CX/GX. It's fairly subtle.
However, like I said earlier in the discussion, 95% of people outside of this board would never know it isn't a B&O TV. It really does look seamless. The design is fairly impressive considering it's 3 separate components combined together. It's hard to know it's using the Stage. Just looks like a TV speaker. You don't see the Stage frame at all.
agree, had the chance to see the set at my dealer the other day. Really nice looking kit!
3 separate components? Does that mean 3 mains leads? Not really all in one system then! 😁
