Multiroom Issue with Turntable/Core to Harmony
Not Answered This post has 0 verified answers | 5 Replies | 1 Follower
BeoJosh
BeoJosh posted on Fri, Oct 30 2020 6:50 PM
Hi All,
New to the forum, and hoping someone can help. I've just completed the first of two major B&O installs in my new home, and am having issues streaming music from my turntable, which is connected to a Core via line-in, to my Harmony 77. The Core will multiroom the turntable music flawlessly to any of the several flex speakers in my home, but won't play properly on the Harmony. The Harmony will recognize it, but no sound comes out. I've also tried multiroom from another turntable connected to an Edge, and it also doesn't work. Deezer FLAC works fine from either the Core or the Edge (or any other flex speaker) to the Harmony, but not the multiroom via line-in on the other device. I've tested all wifi/hardwired connections and everything is strong and stable. I have plenty of other speakers I could listen to the turntable from, but the second part of the install later this year includes 2 pairs of 18s and a 19 to be used with the Harmony, which I primarily purchased to use with the turntable, with surround sound as an added benefit--and now I'm wondering what to do and how to solve the issue. Any suggestions?
Thanks!
Jaffrey2230
Washington DC
Silver Member
Steve from sounds heavenly can probably suggest the correct connection. I don’t think you can connect a turntable directly to a Core’s line in since it doesn’t have an amp and purely a streaming device. I think you can connect the turntable directly to the Harmony...my guess only
My B&O Home:
  • Beolab 8002 + Beolab 2 + Beosound Core with Essence Remote (Office)
  • Beolab 6000 + Beolab 11 + Beosound Core with Essence Remote (Bedroom)
  • Beoplay A9 Mk2 (Living Room)
  • Beosound 1 with wireless dock (Portable)
  • Beosound Balance (Dining)
  • Beoplay H95 (Focused listening, travel)
  • Beoplay H9 (3rd gen) (retired)
  • Beoplay P6 (Portable)
  • Beotime wall clock (hallway entrance)
  • Beoremote X (poor man's Halo Big Smile)
Pat
Pat replied on Sat, Oct 31 2020 8:04 AM
This is well known issue, but if you start playing build in audio source from the harmony - tune in or deezer and then line in, it should play for around 5 mins, then it will stop.
SW update for the Harmony should be available this month.
BeoJosh
Thanks. For the sake of brevity, I forgot to mention the turntable is connected to the core via a phono pre-amp, which is connected via an RCA to 3.5mm line.
BeoJosh
Pat, thanks for the heads up. I tried what you said, and it did exactly what you mention. I really hope the SW update will resolve the issue! By this month, do you mean November?
Carolpa
BeoJosh:
I have a Beogram connected to the Harmony; no issues with multiroom to BS Shape (=Core) and other devices.
Additional info: a BS5e line-in connected to a BLC can be started (the line-in) at the BS Shape and joined by the BV Harmony
EDIT: did some additional testing.
1. when a BLC line-in is involved the Harmony keeps the JOIN connection
2. when a Moment line-in is involved the Harmony plays until the Info on the screen is turned off. At the same time the BS35 keeps the JOIN connection though
Page 1 of 1 (6 items) | RSS
