Beosound Core optical out
Not Answered This post has 0 verified answers | 18 Replies | 1 Follower
wanc1
wanc1 posted on Thu, Oct 29 2020 6:41 AM
I just connected my BeoLab 50 with Beosound Core using optical out.
The speaker does start when I chromecast yet no sound is coming out.
What am I missing?
Klasko
Klasko replied on Thu, May 13 2021 3:23 PM
Hi and sorry to interrupt you, but I have now the same problem can you please tell me how you got it to work.. Thanks.
/Klaus
Klasko
Klasko replied on Thu, May 13 2021 3:26 PM
Hej Henrik.. Jeg har samme problem, og kan se du ikke rigtigt har fået noget svar har du fået det løst og evt. hvordan.?
På forhånd tak.
/Klaus
Jenstm
Jenstm replied on Sun, Oct 17 2021 2:07 PM
Would you be kind to share how you got it to work?
I have the same problem. It all working but after the last auto update to 1.12 there is no optical sound.
I use BL50 with core.
mhslarsen
Hi
I have seen the same behavior with Core and my BL50/BL20 connected via Toslink on the latest Core firmware 1.12.47108 - as a work around you can downgrade to “48 kHz” from “96 kHz” in the “optical-out” setting menu in BS Core.
Page 2 of 2 (19 items) < Previous 1 2 | RSS
