Beogram 8000 og Beocord 8000
Not Answered This post has 0 verified answers | 4 Replies | 1 Follower
tobi
tobi posted on Sat, Oct 17 2020 6:07 PM
Hjælp. Er der nogen herinde der kan hjælpe med en Beogram 8000 der kører ujævnt i hastigheden
Ligeledes har jeg 2stk Beocord 8000 der begge nægter at afspille og spole ligegyldigt hvilke ellers afprøvede bånd jeg prøver at sætte i. De giver bare et KLIK og så slår de fra ?
Har været mit anlæg siden 1981 og jeg vil virkelig gerne kunne høre mine LP er og bånd igen
Kan nogen hjælpe/ henvise til det helt rigtige sted at få dem restaureret / repareret ?
venlig hilsen Tobi
Schletti82
Hi, I can help you with both, the Beogram 8000 and the Beocord.
The only thing is I live in Germany near Munich.
Greatings Markus
tobi
tobi replied on Sat, Oct 17 2020 6:36 PM
Hey Markus
Thank you for your quick replye , and yes i think the distance is too big
best regards Tobi
Dillen
Copenhagen / Denmark
Dillen replied on Sat, Oct 17 2020 8:01 PM
Beogram 8000 will need a thorough restoration.
As a minimum a new tachodisc, a capacitor kit and a good check for cracked solder joints etc.  - As a minimum!
Beocord 8000 will need new belts and idler wheel rubber parts etc.   - As a minimum!
New parts can be found at beoparts-shop.com if you are the DIY-type.
If you need assistance with repairs, PM or email me.
tobi
tobi replied on Sat, Oct 17 2020 11:11 PM
Thank you for your guick reply.
I have sent you an email regarding my problems with my Beogram and Beocords
I hope you can help me
Greatings Torben
Page 1 of 1 (5 items) | RSS
