MCL2P
Answered (Verified) This post has 1 verified answer | 9 Replies | 2 Followers
Geurink
Geurink posted on Fri, Jan 18 2013 9:30 PM
I have a Beosound9000 system 9 whit power link.
Now I have several amplifiers MCL2p witch I will connect to the Link.
The Link cable has 4 wires plus ground.  Normally we only need 2 for L=R signal and 1 for on/off.
The MCL2p needs fully wiring. Isn’t there a way to make this work with the cable I have.
Why dos the MCL2P need the data connection? Can I trick  that.
who can help me
stefan
200 miles from Struer
Answered (Verified) stefan replied on Sat, Jan 19 2013 8:12 AM
Verified by Vienna
Geurink:
who can help me
If you have 4 wires and ground to connect your MCL2Ps via Powerlink, you can use PIN 3/5 for audio L/R, PIN 2 ground,PIN1 for power on/off
and also PIN4 for on/off.
As a workaround you can solder a bridge to PIN 1 - 4.
If I remember correctly, BS9000 also needs a signal on the data pin to detect a connected Powerlink, but I`m not quite sure...(PIN 6-7 bridged?)
You will find this information in older threads here on the forum I`m sure - btw welcome to Beoworld.
For wiring see also:
http://www.beoworld.org/beotech/wiring2.htm
I`d recommend to use Beolink actives connected via Masterlink, if you want to use your MCL2Ps in different rooms.
Hope this helps
Stefan
Johan
Uppsala, Sweden
Johan replied on Fri, Jan 18 2013 9:41 PM
Geurink:
I don't think it does. It doesn't care about the data signal at all, it just carries the data through to the speaker output. I'm pretty sure you can just skip that. You only need it if you have speakers with displays and you want them operational.
/  Johan
Millemissen
Flensborg, Denmark
The MCL2P is an amplifier.
In a MasterLink setup (from the BS9000) you have to use a BeoLink Active for each room/amplifier.
The 2P is then connected to the PL of the ActiveLink and drives passive speakers.
Please specify if I did not understand your question!
Greeting Millemissen
Johan
Uppsala, Sweden
Johan replied on Fri, Jan 18 2013 9:59 PM
Millemissen:
I think he means to use the PL output of the BS9000 and use the MCL2P as amplifier to drive a set of passive speakers. That will work fine.
/  Johan
Millemissen
Flensborg, Denmark
He writes "connect to the Link" and "linkcable" and has "several 2P's.
But maybe you are right.
Greetings MM
Vienna
make an educated guess
Answered (Not Verified) Vienna replied on Fri, Jan 18 2013 11:46 PM
Suggested by Vienna
Geurink:
You don't need the "display data" but only a fully wired cable is able to transmit
"turn on / turn of data" sent by the source (Audio, TV or BeoLink Active)
stefan
Verified by Vienna
Geurink:
who can help me
Hope this helps
Stefan
Geurink
Thanks for al the info, great to get so much response.
I now have made an extra cable whit the pins 1 to 5 connected. When I connect this direct to the Beosound it works.
I have to control the other line where my Beolabs are connected. They work all perfect but on this line my MLC2P still doesn’t.
Anyone now’s how the on/off in detail is working. Pin 1 and 4.
Regards
Vienna
Vienna replied on Sun, Jan 20 2013 8:43 PM
Geurink:
The Pin 1-4 trick is a workaround to connect a MCL2P "solo" - it's not an universal solution in conjuntion with
BeoLabs on the same PowerLink line.
My recommedation is: buy fully mounted PL Cables, either
B&O item # 6271227 for 5m,
B&O item # 6271228 for 10m
stefan
stefan replied on Mon, Jan 21 2013 11:55 AM
Geurink:
Regards
Pin1 on older stuff is power on, Pin4 is speaker on (speaker mute).
Power on on newer equipment like BS9000 is via Pin4. Pin1 and 4 are both 4-5 V.
To connecte an MCL2P to BS9000 it should work with just one wire from PIN4 (BS9000) to Pin1 (MCL2P).
All (newer) Beolabs should be activated by Pin4.
Sorry, I didn`t see anything about Beolabs in your first post. What do you mean by "I have to control the other line..."?.
Which Beolabs are connected? Could you give us a bit more details about your setup? - thanks.
Stefan
Page 1 of 1 (10 items) | RSS
