BeoMaster 3500: touch panel malfunction
Not Answered This post has 0 verified answers | 3 Replies | 1 Follower
KolfMAKER
KolfMAKER posted on Thu, Oct 8 2020 7:46 PM
I have a BeoMaster 3500 on which the last 4 touch buttons on the right don’t work.
I checked them also by detaching the glass, and touching the rubber tips.
All buttons work, except the last 4 on the right.
Any suggestion is welcome.
techhn
techhn replied on Fri, Oct 9 2020 11:19 AM
Hi.
Contact "Dillen".
Dillen
Copenhagen / Denmark
ONLINE
Dillen replied on Sun, Oct 11 2020 7:12 AM
The four rightmost touchpads (7,8,9,st.by) are in the same group = sounds like a strobe problem.
Check TR1, TR2, TR3, TR4 and IC1.
KolfMAKER
Thanks Martin!
I have been able to get a defect BM3500 unit, but with working touch panel PCB, including all the 4 pieces of plastic brackets.
So I have a working unit now, perfect!
To finish this repair, I need to put in new double sided tape. I have two questions about that:
  1. I believe the double sided tape has to be put both on the plastic brackets, as well as on the under side of the glass panel. Is that correct?
  2. I can image that the type of tape matters (stickiness, thickness, etc.). Which tape should I use?
Page 1 of 1 (4 items) | RSS
