Beogram 7000: No datalink, no sound, all play functions normal
Answered (Not Verified) This post has 0 verified answers | 7 Replies | 0 Followers
Gregg
Colorado USA
Gregg posted on Sat, Oct 3 2020 1:50 AM
I tested my Beogram 7000 with my known good Beomaster 4500 (the Beogram 4500 works fine with it). Pressing play the tone arm moves properly and plays the record; and the cartridge is picking up sound. However, datalink is not working, and there is no sound output. I saw an earlier post where Dillen said to check the connector - could that cause both issues?
Thanks,
Gregg
styppen
Silver Member
Suggested by Keith
In order for datalink to work, the Beogram 7000 cable should have 7 pins in the DIN plug. Check if all 7 of them are there.
This however does not explain why there is no sound. Where did you plug the Beogram in the Beomaster? I think 4500 does not have a RIAA preamp so any AUX, TAPE inputs should work fine.
Keith
Shrewsbury
You will not need a preamp, as it was built into the BeoGram 7000.
W.Frankenberg / Gandalf
Heilbronn / Germany
the inner workings of the two Beograms are 99% identical!
If the Beogram 7000 does not play a sound, it can only mean that either a cable is disconnected from the 7-pin DIN plug, or there is a fault in the turntable.
May be due to a defective mute switch or the internal RIAA preamplifier.
wilfried
Heilbronn / Germany
Sorry double post!
wilfried
joeyboygolf
Ely, Cambridgeshire, UK
Someone may have disabled the RIAA to enable the Beogram to work with a Phono input. I once bought a BG4500 that had the legs chopped on the power supply transistors on the pre amp. I just soldered them up again and it worked fine.
Regards Graham
Gregg
Colorado USA
Gregg replied on Mon, Oct 26 2020 8:44 PM
Thanks all for the ideas everyone. I disassembled the DIN plug, and sure enough, every connection was broken except ground. Soldered on a new plug and it is 100% functional!
-Gregg
styppen
Silver Member
Perfect! Really happy you got it working!
Page 1 of 1 (8 items) | RSS
