beomaster 3000 (type 2932)
Struer
London
Posts 88
Silver Member
Struer Posted: Wed, Sep 30 2020 12:49 PM
Hi all,
Bad Beo week 1
My everyday Beomaster 3000 (type 2932) has now developed a fault. When It’s switched on it jumps very briefly to P5 light and clicks (thumping noise throughs speakers) plus a quick flash on all volume lights, but maybe thats normal? and the two lights beside standby flash. It plays all functions properly, but I can’t trust it to use it as a permanent set up with the rest of the system. When removing the 12 pin connector at (1P4) it alleviates the click/jump from P5, So the problem is either on the tuner board or the supply that goes through 12 pin (1P4)
Thats as far as my diagnosis so far.
Dillen
Copenhagen / Denmark
Posts 12,075
Dillen replied on Wed, Sep 30 2020 2:00 PM
Replace the transistor associated directly with the P5 touchpad.
Struer
London
Posts 88
Silver Member
Thanks will try this later
Struer
London
Posts 88
Silver Member
Thanks, replacing the transistor on bottom left didn’t rectify the problem yet
Page 1 of 1 (4 items) | RSS
