Beomaster 3300 (type 2952)
Struer
London
Posts 106
Silver Member
Struer Posted: Wed, Sep 30 2020 12:46 PM
Bad Beo week 2...
HI all on top of bad luck with my back up Beomaster projects my Beomaster 3300 (type 2952) is now not functioning properly. ( my everyday Beomaster 3000 (type 2932) is also out of action.
The 3300 switched on normally and on re plugging it in it clicked straight off. A while later it functioned, played a record through Beogram 2000 (type 5821) the record finished and sometime later the 3300 went into standby with a thump though one speaker. Since then it flicks straight into standby and does not stay on.
Dillen
Copenhagen / Denmark
Posts 13,158
Dillen replied on Wed, Sep 30 2020 1:59 PM
Could be one or more bad capacitors in the power supply or a bad rectifier.
A bad output hybrid IC can also cause this.
Beowulf
Posts 22
Beowulf replied on Fri, Oct 2 2020 9:10 PM
Ironically I have precisely the same issue, fortunately I have a Beomaster 3300 in reserve, I will get it serviced though. :)
Thanks for the information Dillen.
Beowulf
Posts 22
Beowulf replied on Fri, Oct 2 2020 9:11 PM
Struer
London
Posts 106
Silver Member
Thanks for the advice
Struer
London
Posts 106
Silver Member
On starting the amp today cold it worked briefly.
So I guess the fault is permanent if intermittent
Page 1 of 1 (6 items) | RSS
