Beomaster 2400/1900
Struer
London
Posts 86
Silver Member
Struer Posted: Wed, Sep 30 2020 12:41 PM
Hi all, i have a beomaster 2400 and a Beomaster 1900.
Not having the best of luck at the moment with my bombaster. I have just had a look at my 2400 and 1900 for the first time.
Neither of them are functioning properly. The resisters on the Beomaster 2400 were burnt when I bought it so I replaced them and replaced
The two Darlington’s and the resister. Comparing both models which I find easier to troubleshoot the 1900 light is stuck on standby.
The Beomaster 2400 flicks on for a split second and off again. All lights are working and all the remote buttons work activating the correct bulbs.
My thinking Is there must be a serious problem still. I have one of Martins kits, which I shouldn’t use yet, as perhaps adding capacitors etc…at this stage will make diagnoses more difficult.
I have read quite a few archival forums on these issues. Any advice welcomed.
Dillen
Copenhagen / Denmark
Posts 12,067
Dillen replied on Wed, Sep 30 2020 1:56 PM
Check for DC on the speaker outputs - even if only possible during the brief moment it comes out of standby.
Struer
London
Posts 86
Silver Member
Will give that a try. It literally flashes on and off.
And it clicks without the lights if I press any button again before a few seconds have lapsed
Page 1 of 1 (3 items) | RSS
