B&O App Not Connecting to Beovision Eclipse
Not Answered This post has 0 verified answers | 3 Replies | 0 Followers
Austin
United States
Austin posted on Tue, Sep 15 2020 7:46 PM
Hello!
I finally purchased a Bang & Olufsen television! I got a great deal on a current eclipse.
I’m running to a few issues though.
for the life of me, I can’t seem to get the eclipse to add to the B&O app. They are on the same network, I can connect Bluetooth audio, restarted multiple times, but it always fails to add to the app. Up to date on all software as well.
Any ideas?
also, it says it has airplay, but I can’t seem to find it in my AirPlay list.
Fansastic
The Netherlands
Did you try a factory reset on the Eclipse?
BV Eclipse 55 Brass - BL 18 Brass - BL 19 Brass - BL 3 White - BS Moment - BS 2 Brass - BV Horizon 48 - BS3000 - BS 3200 - BS Essence - BL 4000 - V1 40 Black - V1 40 White - BLC NL/ML - H6 -  H4 - E8 Motion - A8 Earphone - Beolit 12 - Beolit 15 - Beoplay A1 Green - Beoplay A3 White
Austin
United States
Austin replied on Tue, Sep 15 2020 10:43 PM
That worked! I just couldn’t find the factory reset button, but I found it!
Does anyone usually turn on all three center channel speakers for a full center when you have separate wireless speakers or are you supposed to turn the left and right soundcenter off?
Curly
FL, USA
Curly replied on Thu, Sep 17 2020 3:36 AM
Congrats on your Eclipse! I’m jealous!
Would you be comfortable sharing what your “great deal” was? I’m trying to garage the market myself and it would help.
I believe the idea is to use the LCR in the sound center all as C if you have separate standalone speakers but Geoff Martin recently suggested in an interview that you might prefer the sound when you use the sound center LCR all as C but decrease the sound center L and R speaker levels by 0.5 or 1db to effectively bring the C in the center channel a bit more forward.
I think he would also encourage you to experiment and say that whatever sounds best to you is what you should stick with! Again, cheers.
Currently: BeoSound Core, BeoLab 17, BeoLab 18
Previously: BeoSound 1 non-GVA
Page 1 of 1 (4 items) | RSS
