Beo4 mk 5 joystick
Not Answered This post has 0 verified answers | 13 Replies | 2 Followers
JKW TAYLOR
Nederland
JKW TAYLOR posted on Tue, Sep 15 2020 2:25 PM
Cannot find any information for the years that the joystick version was in production ?
Anybody know ?
Ken
andybandy
Beo4 type 1710 intro: 2010
Beo4 type 1712 intro: 2012
It was sold side by side with BeoRemote one until it was empty. It was also change from standard produkt nr to an spare part number in the end. So When the last beo4 left struer, its only B&O that know:)
BeoRemote one type 1716 intro 2014
Beoremote one BT type 1717 intro 2016
Beoremote one BT Netflix/Amazon type 1719 intro 2017 w34
JKW TAYLOR
Nederland
Sorry not sure which one I have, I know its with a joystick.
Mk1 is with AV button
Mk2 with DVD button
Mk3 with DTV button
Mk4 Joystick ???
Mk5 ???
What is the differance between type 1710 and 1720
Ken
JKW TAYLOR
Nederland
Sorry I mean 1710 and 1712
Ken
lawrencejmcook
JKW TAYLOR:
Ken
Hi Ken,
If you remove the Beo4 battery cover and batteries there should be a label with the Type No. / Serial No. in the battery bay.
There may be a way to see it on screen - perhaps andybandy knows.
Lawrence
andybandy
Beo4 type 1710 is introduce in 2010. then a smal upgrade in april 2012 with type 1712.
I cannot understand what new top plate is. So not realy sure what the different. Maybe only some smal change in the production with a new aluminium top plate you dont realy will see the different.
Sorry cannot help more=)
But Beo4 with the joystick is the last beo4 made. So if you think about your list with MK1, MK2 and so one. its a MK4. No more after that.
andybandy
You have also the exclusive beo4 cinema for a period, that only was sold to smal dealer out there.
JKW TAYLOR
Nederland
I seem to remeber seeing a hotel version as well.
Can de Beo4 control modern Bang & Olufsen products ? or is there a cut off date?
Ken
Millemissen
Flensborg, Denmark
JKW TAYLOR:
Ken
Since a Beo4 is ir-only, most new products can’t be controlled natively.
However, you can e.g. connect an ir-receiver to a BS Core (or even to a BL50/90) and use ir-control via Beo4/navi.
Please specify, what you aim for.
JKW TAYLOR
Nederland
I know that the Beoremote one came out in 2015 and was IR & BT,
I just would like to know as I have a Beovision 7-40 mk5 and can use my Beo4 mk 4 to control my Tv and stereo.
f I upgrade to een a newer tv can I still control my older other B&O products, as I have read  that the new beoremote is BT only ?
Ken
Millemissen
Flensborg, Denmark
The first BeoRemote One (these are rare nowadays) was ir-only.
The current (including the one with Netflix/Amazon buttons) is ir and bt.
With the BROne, that you but new now, you can control both types - however you will have to switch mode each time you switch from old to new products.
it seems that the coming HaloRemote will not have any ir-capacity.
JKW TAYLOR
Nederland
Are all B&O products from 2020 BT ?
Ken
Millemissen
Flensborg, Denmark
JKW TAYLOR:
Ken
If you count out these add-on receivers, yes!
And the BROne (still) has the ir-sender....oh, and the Essence Remote has support for ir, too.
JKW TAYLOR
Nederland
OK tanks for all the information, good to see that the forum works.
Ken
Page 1 of 1 (14 items) | RSS
