Remote Beo 4 broken. Repair or buy an other one ?
Not Answered This post has 0 verified answers | 5 Replies | 1 Follower
mija
mija posted on Sat, Sep 12 2020 10:17 PM
The nurse who takes care of my wife inadvertently dropped the Beo 4 on the hard floor.
Keyboard/display are OK but the IR diode doesn't seem to work anymore as the Beosound 9000 doesn't respond to inputs. I then tested with an other Beo 4 (normally used with an Ouverture) and everything is fine.
So I am looking for a repair centre that can fix it by replacing the IR diode. Any advice ? (I am located in Belgium but could ship abroad)
Or maybe should I just buy an other one on eBay ?
Thanks anyway for an advice.
Bill Briscoe
Chicago, IL USA
Sorry to hear that you're having trouble with the remote. Have you tried simply resetting the batteries?
leosgonewild
I hade a Beo4 without display that you can get for parts. So you just need to move your working display over to it. Send me a PM Smile
leosgonewild
It is super easy to do work on the Beo4, so you can do it yourself with some guidance Big Smile
mija
mija replied on Sun, Sep 13 2020 4:43 PM
Thanks for the hint but I had already installed fresh batteries to no avail.
Note: I waited until the display went blank to make sure the capacitor got fully discharged before installing the batteries
mija
mija replied on Sun, Sep 13 2020 4:49 PM
PM sent
Page 1 of 1 (6 items) | RSS
