Is it possible to connect a Beolab 3500 directly to a Beogram CD 3500, or does it require a Beomaster inbetween?
/Pindsen
Hi
You do need a Beosound/Beomaster between the Beogram and the speaker to give you volume control. Please let me know which one you choose and I can help with the connection.
Kind regards, Steve
Steve.
www.soundsheavenly.com
Hi Steve,
Thanx for your reply.
If Beolab 3500 cannot be used in such a setup, do B&O then have other speakers where it's possible to connect a Beogram CD directly, maybe via one of the different converters (MCL or others)?
Hi Pindsen,
For most B&O speakers, you need a music system with a volume control (eg. Beomaster 3500) connected between the Beogram CD and the speakers to control the volume. The only options to link speakers directly would be high-end speakers like Beolab 5, or the newer wireless speakers with an Aux input like A2, M5, Beosound 2, Edge, etc with volume control built in.
Kind regards, Steve.
