How do I get sound from my LG TV to my Beosystem 3
Not Answered This post has 0 verified answers | 22 Replies | 1 Follower
Stoobietoo
Exeter, Devon, UK
Stoobietoo posted on Mon, Sep 7 2020 9:32 PM
I have a Beosystem 3 with DVI outs. I am trying to get the sound from my LG OLED screen through the Beosystem.  I've searched the forum and can find a few older posts saying people have done this,  but none actually explain how.
I have a Toslink to SPDIF converter and I have connected it to the TV and set Optical/HDMI ARC out. I have set the Beosystem 3 to AV2 sound input SPDIF.
I cannot get any sound.
Can anyone help with what I need to do. What connections I need to make.
Thanks in advance
Stoobie
leosgonewild
Try changing the type of sound your tv outputs. (PCM/Passthrough/Auto)
Johan
Bolsward, NL
Johan replied on Tue, Sep 8 2020 9:24 AM
This is how I set the TV (55C9) and it works fine with an optical to coax converter. Optical only and Auto Digital Sound Out.
Hope this helps!
x16szr
x16szr replied on Tue, Sep 8 2020 11:02 AM
how do you remote the LG via the Beosystem?
With PUC and how is the technical way to do this?
What about remote turn on and off the LG and switching through TV, Netflix,
Apple TV 4 etc.?
Greats and thanks!!
I have an Beosystem 4.
Beosystem 4 , Beoremote One, Samsung LED 65 Zoll, ATV4 PUC, BL 8000 Frontspeaker, Center BL 7.1, BeoPlay S8 black Rear Wandhalterung, Beosound Essence MK2 mit IR an Beolink passiv an Bose 161 weiß, Beomaster 3000 mit Beocord 3000 an BeoVox CX50 weiß, BeoCom 1401 mit IR Control, BeoCom 2000 weiß, Beoplay M5, Ex-Beosound Ouverture RDS, Ex-BV 10-40 MK3 mit Beo4 DTV an Dreambox 500V2, Ex - Beoplay V1-40 weiß , Ex-BV 8-26 mit Beo4 DTV an Technisat Digit S2e PUC, ex BeoSound 3, Ex-Beolit 12 Darkgrey, ex B&O A8 Earphones
stefan
200 miles from Struer
Stoobietoo:
Thanks in advance
Stoobie
Did you not get the PUC solution from comeonbert?...
https://forum.beoworld.org/forums/t/38809.aspx?PageIndex=3
Stefan
stefan
Stoobietoo:
Thanks in advance
Stoobie
Did you not get the PUC solution from comeonbert?....
Stefan
Stoobietoo
Exeter, Devon, UK
x16szr:
How do you remote the LG via the Beosystem?
What about remote turn on and off the LG and switching through TV, Netflix, Apple TV 4 etc.?
Greats and thanks!!
To control the LG I used a Beo5 remote control. It took a lot of tinkering and worked well. But, I far prefer the Beo 4 so I have bought a LinTronic. I asked my local dealer if they can put LG TV codes into the  Beosystem 3 and they said it is not possible.
Stoobie
Stoobietoo
Exeter, Devon, UK
Johan:
Hope this helps!
Thanks Johan. My. Sound menus looks slightly different but I'll give it a go tonight. Do you also have an HDMI cable connected. I only have the DVI to HDMI connected.
Stoobie
Johan
Bolsward, NL
Johan replied on Tue, Sep 8 2020 3:40 PM
Hi Stoobie, my BeoSystem3 has HDMI outputs, but I am confident that that is not the problem. I also have connected the digital coax (from the toslink to sp-dif) to AV2. Let me send you a photograph of that setting also (in Dutch though).
Johan
Johan
Bolsward, NL
Johan replied on Tue, Sep 8 2020 3:42 PM
Stoobietoo
Exeter, Devon, UK
Thank you, my little bit of Afrikaans helps here Big Smile
Stoobie
Stoobietoo
Exeter, Devon, UK
Thanks for all the suggestions but none worked. My sound menus on the TV are slightly different but none of the options seem to work. I think I might have to check my convertor box as that may not be working! I can see red light down the Toslink cable so assume the TV out is working.
What I plan to do is disconnect everything on the weekend, reset the Beosystem and start from scratch.
Johan
Bolsward, NL
Johan replied on Wed, Sep 9 2020 6:44 AM
That's a pity Stoobie. Maybe a faulty converter indeed. Mine is this one:
There is no indicator light even, so I was crossing fingers too when I set it up lately! I powered it with a USB cable and I did buy a specific coax sp/dif cable as I assumed a normal rca/cinch cable would not work.
Hope you will get it working soon!
Johan
Bolsward, NL
Johan replied on Wed, Sep 9 2020 2:05 PM
Stoobietoo:
x16szr:
Greats and thanks!!
Stoobie
I hope this is not true! I was planning to try and do this sometime with my BS3!
Stoobietoo
Exeter, Devon, UK
Johan,
You may find a dealer that will do that for you but my local dealer emailed me to say it is not possible. I cannot understand why it is not possible. The discrete codes for LG OLEDTVs are vailble oline. I downloaded ON & OFF and put it on my Beo5 so they must be able to do it. I think you need to find a dealer who knows how to use the PUC tool properly.
Stoobie
Page 1 of 2 (23 items) 1 2 Next > | RSS
