V.MEM sound not showing up on 3200
Answered (Verified) This post has 2 verified answers | 4 Replies | 2 Followers
AymanG
AymanG posted on Tue, Jan 15 2013 6:48 PM
Hello.
I am hoping someone can help me resolve this.
Room A: I have a BV4-65 connected to a BeoSystem 3. 5 speakers. Also connected to the BeoSystem 3 is an AppleTV (accessed as V.MEM on remote).
Room B: I have a BeoSound 3200 (with integrated speakers) which has a BeoLab 2000 as well.
The 3200 and BeoSystem are connected with MasterLink.
I am able to listen to music playing on the 3200 on the speakers in room A.
I also can listen to TV sound on the 3200.
What I can not seem to be able to do is listen to the AppleTV sound on the 3200. When I select LIST > AV > V.MEM at the 3200, what shows on the 3200 is V.Tape and no sound. Again, if I select TV at the 3200, I get TV sound but it does not seem to pipe in the V.MEM (AppleTV) sound.
I hope I have explained this well and that someone can help. Thanks for your help.
Raeuber
Germany
Verified by rednik
Hello AymanG,
you have to connect your ATV also analogue, not only via HDMI. Therefore you need a digital-to-analogue converter: optical wire from ATV to converter and two cinch cables from converter to BS 3.
Regards
Räuber
Raeuber
Germany
Verified by rednik
You can use a scart connection with an adapter like this:
http://www.amazon.de/mumbi-SCART-AV-Adapter-Umschalter-In-Out/dp/B003JGQFFG/ref=sr_1_1?ie=UTF8&qid=1358284407&sr=8-1
/Räuber
Raeuber
Germany
Verified by rednik
Hello AymanG,
Regards
Räuber
AymanG
AymanG replied on Tue, Jan 15 2013 9:01 PM
Thank you Räuber for you reply. The cinch cables.. where do I connect them to on the BS 3? Do I need to configure in BS 3 settings?
Thank you again.
AymanG
Raeuber
Germany
Verified by rednik
/Räuber
DoubleU
Why not use one of the AV-sockets without scart, but with L/R RCA sockets?
Page 1 of 1 (5 items) | RSS
