Masterlink puzzle - no video sound distribution on BS9000 or BL Passive
Not Answered This post has 0 verified answers | 2 Replies | 1 Follower
Gregg
Colorado USA
Gregg posted on Fri, Aug 28 2020 4:46 PM
I recently added a BV7-40 to my Masterlink network, and attached an AppleTV to it. I use the AppleTV for video but also for Airplay from my iPhone to distribute music. Previously, with my BS3 with an AppleTV attached to "TV" I was able to distribute music. In the new setup, after many different experiments, I've failed to be able to play music from the BV 7-40 from either my BS9000 version 2 with the upgraded 2.21 software, or a Beolink Passive. Airplay plays just fine through the BV7-40 speakers, using the command AV, V.MEM.
The AppleTV is connected to the BV7-40 MK III AV1 configured for V.MEM (same as V.TAPE).
All units are connected to the same ML Distribution box, with the BV7-40 connected to VIDEO MASTER, the BS9000 to AUDIO MASTER, and then the BL Passive and a BLGW. The BV7-40 and BS9000 are both designated as Video and Audio masters in the BLGW.
Option settings:
BV7-40: Video Option 2
BS900: Audio Option 2
BL Passive: Link Option 6
When I command the BS 9000 to either AV, VMEM, or just VMEM, it properly displays VMEM, and it turns on the BV7-40 into AV VMEM mode. However, no sound comes out of the Powerlink socket nor the TAPE OUT line from the A AUX port on the BS9000. The same for the BL Passive, whether I command it from the Beo4 remote, or press the MUTE button to turn it on after sending the AV, VMEM command to the BS 9000 separately.
CD, A AUX, and Radio all distribute audio properly from the BS9000 on both the BV7-40 and the BL Passive.
I have also tried designating the AV1 input for the AppleTV to VAUX, to no avail.
So, any ideas on why audio from a video source on the BV7-40 is not distributing? This is a fundamental capability of Masterlink.
Thanks,
Gregg
Gregg
Colorado USA
Gregg replied on Fri, Aug 28 2020 4:48 PM
Another note, if it matters. The AppleTV is connected via HDMI to AV1, so it is digital sourced audio. Masterlink is analog audio of course.
Carolpa
Gregg:
limitation of distribution of digital sources of the BV7 is the cause of no video sound (maybe it was solved with the evolvement to the later types, I do not know)
The next generation video system, such as the Beosystem 3, didn't have this limitation.
 Solution: split the HDMI out of the ATV to HDMI + analoge Audio (RCA) with a converter.
Page 1 of 1 (3 items) | RSS
