Beovision 4 - Control without Beo4
Answered (Not Verified) This post has 0 verified answers | 1 Reply | 1 Follower
mcalzolani
Silver Member
mcalzolani posted on Wed, Aug 12 2020 7:25 AM
I have a Beovision 4 50" with DVI Input. I wish I would to use it only as Monitor because my Beosystem 2 is just broken. My question is how can I turn on and turn off the TV without using the Beo4.
Is someone of you found a solution about a similar issue?
Thank you
beojeff
USA
Suggested by beojeff
A generic Panasonic remote can do basic functions such as on/off and selecting the input. the IR sensor is behind the bezel in the lower left corner. You might need to point the remote up from below the bezel.
A second-hand BeoSystem 3 can usually be found at a good price and give you a great upgrade in picture, connections, and functionality.
Page 1 of 1 (2 items) | RSS
