Relay part #
Not Answered This post has 0 verified answers | 1 Reply | 1 Follower
GotHifi
GotHifi posted on Fri, Jul 31 2020 8:12 PM
Does anyone know the part # for the relays on the CDX decoder board? I need to replace mine. Thanks.
Dillen
Copenhagen / Denmark
Dillen replied on Fri, Jul 31 2020 8:33 PM
Which relay?
And what would you do with the part number?
If it's the reed relays that sit near the audio output, the usual problem is bad reed elements.
New elements are available from Beoparts. Use the contact form.
If the reed relays coils are not activated, resolder the rivet vias on the decoder board and the power supply, and any other bad connection/solder joint you can find.
Also check the continuity of the coils themselves.
Page 1 of 1 (2 items) | RSS
