Netradio stations list update BM5
Not Answered This post has 0 verified answers | 47 Replies | 0 Followers
Fritz
Fritz posted on Tue, Jul 21 2020 11:13 AM
Dear All
The BM 5 Netradio Station List seems to be EOL according to Beo Support UK.
Latest update are from 15-12-2019 / 10-01-2020. This seems to be the last and final.
Brgds/Fritz
Fritz
Fritz replied on Sat, Aug 22 2020 4:26 PM
This is correct, and BS5 unit had to be connected to BM5. (DNLA Music server)
And the BV11 medieplayer did the job for N.Music and N.Radio.
Carolpa
Fritz:
So this make sense, Twonky distributed the files stored on the HHD of the BM5 to your BV11.
But you never distributed N.Music playing on the BS5 to a NL device. And if you payed N.Radio on the BV11. That was it's own source, it had nothing to do with your BS5.
Fritz
Fritz replied on Sat, Aug 22 2020 7:45 PM
To clarify: The NL protocol replaced the ML protocol. In my post I refer to Network:
A special setup was needed and using BEO6 as described ealier.
BV11 received the signal, transfered the signal to the speakers on BV11.
No Picture etc on BV11.
What others has decribed was the way to do efter softwares were updated, includind updates to the ML/NL converter, if used..
I belive that the media player was working in the background on BV11, as the BS5 display was active with the correct souce  And the correct source was playing.
The information the the BEO6 display and BS5 Display was also the same.
BEO6 was sending commands and receiving information on the BEO6 Display.
However we are gettinng away from the BM 5 N.Radio stations list update and BS5 N.Radio station list update.
Page 4 of 4 (48 items) < Previous 1 2 3 4 | RSS
