Netradio stations list update BM5
Not Answered This post has 0 verified answers | 47 Replies | 0 Followers
Fritz
Fritz posted on Tue, Jul 21 2020 11:13 AM
Dear All
The BM 5 Netradio Station List seems to be EOL according to Beo Support UK.
Latest update are from 15-12-2019 / 10-01-2020. This seems to be the last and final.
Brgds/Fritz
Weebyx
Denmark
Weebyx replied on Tue, Jul 21 2020 12:53 PM
Fritz:
Dear All
Brgds/Fritz
Does that just mean that they will not maintain the list anymore ? My BS5 has a "Last N.RADIO Update" of 2020-06-19. And I could see in the logs that it downloaded 441 logos today.
/Weebyx
Fritz
Fritz replied on Wed, Jul 22 2020 9:36 AM
BM 5 N.Radio Station list will not be updated, Only BS 5.
Brgds/Fritz
Razlaw
ONLINE
Razlaw replied on Wed, Jul 22 2020 3:11 PM
That does not make sense? The Beosound 5 is connected to a Beomaster 5.
Fritz
Fritz replied on Wed, Jul 22 2020 6:53 PM
It make sense allright, BM 5 can work as a standalone without BS 5.
The BM 5 software is cheking when booting up, if BS 5 module is connected, and loading the BS 5 software version. If not connected, it's loading the BM 5 software.
Try for youself and see.
Pls remember that BM 5 was also sold as a standalone unit..
Brgds / Fritz. .
Carolpa
Fritz:
Brgds / Fritz. .
Please check the Register of the BM5/BS5 in both cases. Do you see other references to Netradio in both cases??
Fritz
Fritz replied on Wed, Jul 22 2020 11:39 PM
Yes
On BS 5 latest update 13-07-2020
On BM 5 latest update 10-01-2020 or 15-12-2019.
Brgds/Fritz
Carolpa
Fritz:
Yes On BS 5 latest update 13-07-2020 On BM 5 latest update 10-01-2020 or 15-12-2019. Brgds/Fritz
on BS5? How do you mean?
It is always on the BM5 ( stand alone or as combi)
Carolpa
Fritz:
another question: what about the difference in Netradio sw in the Register
Weebyx
Denmark
Weebyx replied on Thu, Jul 23 2020 11:56 AM
Fritz:
Yes
Brgds/Fritz
I am confused.
Are we talking about Beosound 5 Encore here ? The Beosound 5 in combination with Beomaster 5, is just display and controller ?
/Weebyx
Fritz
Fritz replied on Thu, Jul 23 2020 2:49 PM
We are talking about Beomaster 5 with or without Beosund 5 connected.
With Beosund 5 connected N.Radio Station List updates are still comming.
Beosound 5 Encore is another product.
Brrds/Fritz.
Weebyx
Denmark
Weebyx replied on Fri, Jul 24 2020 8:52 AM
Fritz:
Brrds/Fritz.
Ok, it just seems odd that the BM5 standalone does not get the update, I thought it was the same SW they where running ? I guess what they mean is if it is build into a BV9 or similar ?
/Weebyx
Fritz
Fritz replied on Fri, Jul 24 2020 10:55 AM
Correct.
The BM 5 is actually an update of the BeoMedia 1.
The issue was that one needed a TV to prgramme the BM 5.
Then B&O came uo with the BS 5 solution, så it could work as a standalone without at TV.
As you have written before, the BS 5 is the replacement for the TV, but with a lot more features than the BM 5 itself.
Brgds/Fritz
Carolpa
Carolpa replied on Fri, Jul 24 2020 11:41 AM
Fritz:
Such as?
beolion
ONLINE
I used to only have the BM5 connected to a tv but after a year I ended buying the BS5 as well. Additional features as I remember.
Much easier to scan your music compared to TV
You can assign N.RADIO to RADIO and N.MUSIC to CD
You can assign BM5 as DNLA server
Spotify integration (when it worked)
You can use the USB input on BM5 with a.aux
You can have the BM5 “on” all the time for quick start up
Ability to attached a CD to play and/or rip CD (I don’t have this though)
That is what came to my mind.
Page 1 of 4 (48 items) 1 2 3 4 Next > | RSS
