Beolab 2 issue?
Not Answered This post has 0 verified answers | 3 Replies | 0 Followers
Espen
Espen posted on Mon, Jul 13 2020 5:46 PM
Picked up a Beolab 2 and it has this ring/inprint about 5-7 cm diameter in the center of the bass driver, and i dont know if this is an issue or if it is normal. It was not visible in the picture or the light i reviewed the unit in, so i bought it and now i am a bit concerned.
So what do you think? Can i relax or should i be worried there are issues with this sub?
regards
Espen
leosgonewild
A picture would help Big Smile
Espen
Espen replied on Mon, Jul 13 2020 8:39 PM
Ok, not sure if i can get it to work, but ill try.I was unable to load from site library.
leosgonewild
Looks like it has been placed with that side up and something has been standing on it?
I would jus try it on low volume and gradually put it louder. You will hear if something is wrongStick out tongue
Page 1 of 1 (4 items) | RSS
