Beovision 7 Can you switch off the screen while still hearing the sound?
Answered (Verified) This post has 1 verified answer | 3 Replies | 1 Follower
bigbruggsy
bigbruggsy posted on Wed, Jul 1 2020 12:24 PM
Hi All, This may seem a weird question. But sometimes I use the beovision 7 to play internet radio through a nvidia shield I have hooked upto it. When I use the shield to play internet radio, I dont really like to leave the screen on. Is there a way to have the screen turned off but still have the TV on playing sound?
Thanks all.
Beolab 8000 x 2
Beolab 1
Beolab 2
Beovision 7-40
Beosound 9000
Beosound Ouverture
Beolit 12
matador43
Verified by bigbruggsy
Hi.
If you're using an early AV Beo4 remote pressing the AV key before any source should start the audio only on that source.
If you're using a latter Beo4 remote you must add the P.MUTE key to mute the picture.
If you're using a Beo5/6 remote and are able to program it. I believe that selecting a video source from a radio entry open the audio only.
It works with an Airport Express connected to the V.MEM scart input on my BC6.
matador43
Hi.
bigbruggsy
Thanks for that Matador43, Out of the 3 beo4 remotes I have, one was new enough to have the P.MUTE command. Now I can have the screen off.  Thanks
Beolab 8000 x 2
Beolab 1
Beolab 2
Beovision 7-40
Beosound 9000
Beosound Ouverture
Beolit 12
Ravsted
Learned something new ! Thanks...
Page 1 of 1 (4 items) | RSS
