Beosound 5 / Beomaster 5 - Wireless
Not Answered This post has 0 verified answers | 12 Replies | 0 Followers
nigel123
nigel123 posted on Sat, Jun 27 2020 8:35 PM
Anybody with a Beosound 5 / Beomaster 5 setup able to make a Wifi connection as a opposed to a Wired connection. If so would they be kind enough to share their solution
Thanks Nigel
beolion
beolion replied on Sat, Jun 27 2020 11:03 PM
Do you mean using wireless to BM5 instead of a cable?
Stan
Stan replied on Sat, Jun 27 2020 11:09 PM
I have mine wired to an airport express.  Works great.
beolion
beolion replied on Sat, Jun 27 2020 11:19 PM
I found a wireless USB dongle many years ago, but it is hard to find one today with drivers for WindowsXP today.
nigel123
Yes correct, I currently use an Ethernet cable.
Esax
Esax replied on Sun, Jun 28 2020 9:21 AM
The Sandberg wifi dongles does usully have XP support and no need for extra drivers.
https://sandberg.world/sv-se/product/Micro-WiFi-USB-Dongle
Beovision 7-55 MK1 red, Beolab 10 red. Beolab 50, all black. Beolab 17 broken ice. Beolab transmitter. Apple tv4 and apple express 2.
nigel123
I now have obtained a compatible wireless dongle how do I add it to my network
beolion
You have to start the BS5 service menu and enter windows xp and connect it to your network
nigel123
Thanks I presume you need a keyboard/ mouse
beolion
Yes that is correct. There is USB in the back of BM5
TWG
TWG replied on Mon, Jun 29 2020 9:31 PM
Just use any wireless access point / repeater with an Ethernet / LAN port. set it up for your wireless network and connect it with a LAN cable to your Beomaster 5 and you're ready to go and you avoid messing around with the Beomaster 5 software.
An Example is the Airport Express or other small access points.
Millemissen
Flensborg, Denmark
Agree - that would be a better and easier solution.
Orherweise consult this guide - page 32....
http://www.iconic-av.co.uk/manuals/Beosound5_InstallationGuide-eng.pdf
nigel123
nigel123 replied on Mon, Jun 29 2020 11:37 PM
Thanks for your help here. I will go down the Wireless Dongle route. If that fails will try an Airport Express
Page 1 of 1 (13 items) | RSS
