Beolab 7.1 vs Beolab 7.2?
Not Answered This post has 0 verified answers | 25 Replies | 2 Followers
tuttivini
tuttivini posted on Tue, Jun 23 2020 6:04 PM
Today I borrowed my dad's Beolab 7.2.
Preparing for a 5.1 setup, mentioned in this topic: https://forum.beoworld.org/forums/t/42873.aspx
WauWWW, what a sound. Unbelievable.
Funny thing is I tested it in a 'dual-stereo- setup', because I don't have a surround processor yet...
So Beolab 7.2 in the centre, beneath my LG Oled, and Beolab 8000's mk2's left and right.
Connected to a B&O Playmaker.
The 7.2 plays just a little bit louder than the 8000's and this works excellent.
Voices in movies are crisp. You hear extra details. And bass is very good, did some 40hz test tones and 7.2 can deliver, in contrast to the 8000 mk2's!
Of course I know this isn't connected/behaving like a dedicated centre speaker, but it opens up possibilities.
It sounds great and already an upgrade untill I buy a surround processor (like asked in the other topic).
The interplay between the 7.2 and the 8000's is astonishingly good. I think this is also because it includes the same type of tweeters / everything is designed the same way.
So, I'm looking for a second hand Beolab 7.
What's the real world difference between the 7.1 and 7.2? (sound quality)
Is there, for example, a difference in the lowest bass frequence? I see 4.2liter volume for the 7.1 and 5.2liter for the 7.2...
tuttivini
Any other forum members who compared the 7.1 to the 7.2?
Can we confirm that the extra cabinet/internal volume makes no different to the sound/lowest frequencies?
Beobuddy
Utrecht, The Netherlands
Beobuddy replied on Sun, Jun 28 2020 11:26 AM
The electronics inside are the same. No difference.
Maybe the BL7-2 produces a broader stereo sound when use with (stereo) music? The drivers on the left and right side are more separated from each other.
leosgonewild
Helsinki, Finland
Silver Member
I have had 7.1, 7.2, and 7.6. Only difference I have noticed is stereo separation.
Peter Pan
tuttivini
I bought a second hand complete Beovision 7-32 mk3, with motorized floor stand and Beolab 7.1, for a verrrrrrry good price last week!
I only need the Beolab 7.1 but connected a PC with DVI and RCA audio to the BV7 to test it and whowww.. 10+ years old, but what a lovely timeless design!!!
Sound, picture (I know, only 720p and brightness is quite low in daylight), easy operation, motorized movement, hidden dvd player,  etc. is EXCELLENT!!!
I'm going to disassemble the Beolab 7.1 and use it in my living room, making my own bracket and mount it to my wall, beneath the tv, like @OldJack mentioned.
First I'm going to connect it to my B&O Playmaker, making a 'dual stereo setup' with my already existing 8000's.
Later I'm going to look for the smallest/best 3.0/3.1/5.1 surround setup with a suitable decoder so the 7.1 becomes a dedicated centre channel.
The BV7-32 goes to my parents. They can use it in their bedroom.
The motorized floor stand is going to be used for a 'try-out': I'm going to make my own vesa compatible bracket, so the stand can be used with non-b&o tv's up to 65" (like STB brackets with their LG C9/CX oleds, looks beatifull!!!). The motorized part is going to be controlled with a separate ir/rf remote or maybe usb from tv, so it automatically turns to a specific when non-b&o tv turns on, like original....
tuttivini
Done!
Placed the Beolab 7.1 on a self made bracket to the wall and used the same 'speaker-cloth' on the grill, matching the Beolab 8000's.
All wires directly invisible into the wall, going to the Playmaker, hidden underneath the shelf.
Very happy with the result.
Peter Pan
Yes - thumbs up  Idea
Stand alone setup.
Teyelvis
Doesn’t create hiss or humming noise from the trigger source?
epkgael
Awesome work!!! I love it Lets have a Party !!!
I ended up here thinking of a 7-2 as center speaker setup but 7-1 might suit me better since it's not as deep and I get the bass from the BL 2 anyhow.
I love the upgrade with the front cloth in darker color - was it an easy operation to get the cloth to stick? Can you share some intel on how you did it?
leosgonewild
Helsinki, Finland
Silver Member
I did this similar the other day.
I just sprayed glue on the edge from behind and stretched speakercloth onto it.
epkgael
Just bought a 7.1 together with a 7-32 motorised stand. Will put my LG tv on it with the 7.1 modified as you've done.
Realised that the aluminium front came off easily so next items are some glue and speaker cloth :)
Unfortunately I found out that the 7.1 is not all healthy. There is a hissing sound when turned on and sometimes it doesn't turn on. So it needs some service first... Sad
Page 2 of 2 (26 items) < Previous 1 2 | RSS
