Beolink Converter NL/ML Issue
Answered (Verified) This post has 1 verified answer | 12 Replies | 0 Followers
dahiyas
United States
Silver Member
dahiyas posted on Sun, May 31 2020 10:25 PM
I have a Beolink Converter NL/ML that refuses to follow any of the setup commands Sad.
The status LED continues to flash green from the moment power is switched on to, going through the setup for factory reset - press setup button, count 5 red blinks, release, press within 3 secs, orange led and then back to blinking green.
btw - the green flashing rate is always same..no change in speed for any operation.
Have tried -
1. With nothing but power connected.
2. Power and network connected - to computer directly.
3. Power and network connected - to network directly. (DHCP)
Read through the manual and couldn't find anything useful.
Any suggestions please ?
Pat
Answered (Verified) Pat replied on Tue, Jun 2 2020 11:57 AM
Verified by dahiyas
The pcb 01 with pre-programmed eeprom has to be replaced. If you’ve tried power off and leaving for longer unplugged, factory settings, connecting directly to the router instead via switch ( if that’s the case ) etc, that’s the only option.
Fansastic
The Netherlands
ONLINE
Had the same, see this post
https://forum.beoworld.org/forums/t/42390.aspx
BV Eclipse 55 Brass - BL 18 Brass - BL 19 Brass - BL 3 White - BS Moment - BS 2 Brass - BV Horizon 48 - BS3000 - BS 3200 - BS Essence - BL 4000 - V1 40 Black - V1 40 White - BLC NL/ML - H6 -  H4 - E8 Motion - A8 Earphone - Beolit 12 - Beolit 15 - Beoplay A1 Green - Beoplay A3 White
dahiyas
United States
Silver Member
Thank you..am glad things worked out for you.
I had given up yesterday and switched of the unit and tried again this morning after 12 hrs..nothing connected ..same thing..the moment you apply power..green light starts blinking...
It seems like a PC with disk crashed..there is power but no software to boot the hardware.
Hope this doesn't turn into a expensive paperweight  :-(
You mentioned about the switch being bad - Was it the setup switch ?
Fansastic
The Netherlands
ONLINE
dahiyas:
I was referring to my network switch. The converter did not get a good internet connection or IP address appointed.
Did you try a different lan cable?
dahiyas
United States
Silver Member
Got it. Yes, I have tried brand new CAT7 cable (tried to follow all requirements in the installation guide), setup a standalone network..
No luck.
Have written to Beocare..let's see what they come back with.
Pat
Verified by dahiyas
dahiyas
United States
Silver Member
Thanks Pat..How much does the PCB cost ?
I assume that's the small PCB connected with two ribbon cables ?
Pat
Pat replied on Tue, Jun 2 2020 2:42 PM
There are only 2 pcb’s inside - pcb 04 psu and pcb 01 main board - the one with all of the sockets and connectors. The part itself £150 + vat, the faulty module has to be returned to B&O DK, otherwise price of the part will be £301 + vat. Labour cost on top of that.
dahiyas
United States
Silver Member
Thanks Pat.
Pat
Pat replied on Wed, Jun 3 2020 1:14 AM
You’re welcome Smile
dahiyas
United States
Silver Member
dahiyas replied on Tue, Jun 16 2020 10:37 PM
I got a quote of 945 USD !! So looks like I have a expensive teacup coaster for now Big Smile
Would you happen to know the part no. ?
Thanks,
dahiyas
United States
Silver Member
dahiyas
United States
Silver Member
Page 1 of 1 (13 items) | RSS
