Beosound 9000 mk3 CD scratching
Not Answered This post has 0 verified answers | 5 Replies | 1 Follower
DenNik90
DenNik90 posted on Sun, May 31 2020 3:34 PM
Hey fellas
I'm on my quest to acquire my first B&O equipment and I'm having a quite delightful situation between a mk2 and a mk3 at almost similar price.
Obviously I want the mk3 but it appears to have an issue of CDs scratching against the "arm"
https://m.youtube.com/watch?t=1s&v=JCxx0K_yCxE
Is it fixable?
All help is appreciated as a newcomer :)
leosgonewild
Since this unit can be mounted different ways (horizontal, vertical, lying, leaning), there are screws on the back that needs to be set in correct position.
https://forum.beoworld.org/forums/t/12369.aspx
And welcome to the forum Big Smile
matador43
Hi and welcome to Beoworld,
You'll discover that in that area (almost) all is fixable! Big Smile
In your case, its difficult to say but it could be as easy as adjusting the clamper height (two screws) or more complicated as the optical disc (in the clamper) twisted. Do the discs revert to position as set after they're read ?
On a different note, unless you really need N.Music and N.Radio, with i doubt if its your first B&O material, there is no reason to choose MK3 over MK2.
MK2 laser is easy to replace when it fails, MK3 is not. There is a little exception to that rule you can learn about on the forum, but its something worth considering.
Cheers.
DenNik90
Thanks for the reply.
It's the sellers video, he appears to be smart enough to know it too.
I've read three different manuals and watched several videos trying to find a solution to the subject, feels like I've gotten a half degree in the engineering of the device by now haha
Thank you, it would be interesting if that is all that is wrong.
DenNik90
Hey
Thank you, if that's the definitive difference between the two, I will push for the mk2 as it seems to be near perfect condition.
Have a great day
DenNik90
Hey
Have a great day
Page 1 of 1 (6 items) | RSS
