Beosound 5 connecting to Beosound 9000 Mk2
Answered (Verified) This post has 1 verified answer | 18 Replies | 2 Followers
nigel123
nigel123 posted on Sun, May 24 2020 3:42 PM
Hi
My current set up is Beosound 9000 mk2  with input to a Beoiab 2 with output through Beolab 8000's.
I have a recently acquired a Beosound 5 / Beomaster 5, 1 TB and have attempted to connect the Beomaster  to the Beosound 9000 via Master Link and hear no sound when I select NMusic on the Beosound 5 but do when I select Radio.
Research into this issue as led me to believe that my BeoSound 9000 mk2 is not compatible with NMUSIC a software update is required to the BS9000.
I have 2 questions here :
1) Is my research correct and if so if there is a workaround to this issue
Nigel
nigel123
Verified by nigel123
Have done that and still no joy. I am attempting to listen to music by using the wheel and dial on the Beosound. Obviously when I play a CD I select CD on the Beosound 4 Remote. Do this need to be  configured / updated  in any way
Razlaw
Razlaw replied on Mon, May 25 2020 1:01 PM
Do you have the Beosound 5 set as audio master?
Beolab 50s Beolab 9s Beolab 12-3s Beolab 1s Beolab 6000s 2 pairs Beolab 4000s Beovision 7-55 Beovision 10-40 Beoplay V1 32 inch Beovision Avant 32 inch Beosound 1 (CD player) Beosound 3000 Beosound 5 Core Essence MKII Beoplay M5
stefan
200 miles from Struer
stefan replied on Mon, May 25 2020 1:52 PM
RADIO should work in any case - it`s a BS9000 source.
Did you set your BS5 to NO AUDIOMASTER ?
If yes, you should have N.MUSIC and N.RADIO as sources on BS5 (and maybe A.AUX)
BS9000 has CD and RADIO as sources.
When you activate your BS5 selecting N.MUSIC, BS9000 should also start, displaying N.MUSIC (same wit N.RADIO).
Stefan
nigel123
Just to confirm I have the following four options in MODE
- NMUSIC
- NRADIO
- AAUX
- SETTINGS
I am still not getting any Sound
nigel123
 I am selecting NMUSIC
Razlaw
Razlaw replied on Mon, May 25 2020 2:36 PM
Go to MODE. Then SETTINGS. Press GO.
Then ROLES
Is Audio Master yes or no?
nigel123
Audio Master = YES
nigel123
Audio Master = YES
nigel123
YES
Razlaw
Razlaw replied on Mon, May 25 2020 3:51 PM
Try changing it to NO.
nigel123
nigel123
nigel123
nigel123
nigel123
Page 1 of 2 (19 items) 1 2 Next > | RSS
