Beovox Cona left out doesn’t work
Answered (Verified) This post has 1 verified answer | 2 Replies | 1 Follower
riis
Denmark
riis posted on Sat, May 23 2020 5:32 PM
I just bought a Cona that should add some more bass to my Beocenter 9000 with CX100 speakers. The problem is that the left out doesn’t work, no sound at all.
I have opened it and everything looks ok. No loose wires, no leaking capacitors. The Cona was bought privately online and the seller said it worked perfectly, but...............
/riis
sonavor
Texas, United States
Verified by Peter
You can't always tell a problem just by inspection. Broken connections and failed solder joints can look normal to the naked eye. If you have a DMM (multi-meter) start checking continuity of the wiring. There is most likely a break somewhere.
-sonavor
sonavor
Verified by Peter
-sonavor
riis
Denmark
riis replied on Sat, May 23 2020 9:10 PM
You were right sonavor. It was a break in one of the DIN-plugs in the Beocenter. Thanks for your advice.
/riis
Page 1 of 1 (3 items) | RSS
