5V DC USB charger for Beo5?
CrazyCatman
Copenhagen, Denmark
Posts 7
CrazyCatman Posted: Sat, May 23 2020 12:15 PM
I have three Beo5 remotes, a wall charger and two desk charger; unfortunately one of the chargers/docks don't have the wall socket.
Well, I have plenty of USB charging plugs - also Mini-USB male charging plugs - but they are are 5V (mainly 2A) as they were designed for mobile phones, but the chargers for the Beo5 are 4.7V 400 mA. And I wouldn't want to fry anything so I have to ask; anyone knowing of 5V is good enough for the 2.4 V battery?
On the fresh installed battery (non-original GP) I installed the resistor from the original Sanyo battery, and I imagine this is installed because of the charger being 4.7V and not 2.4 like the battery.
So... 5V DC or not?
blanknarrator
Posts 4
Hi Catman,
I believe that the only way to charge the batteries installed into the Beo5 is with the included charger. I tried every combination of USB charging cables and wall adapters; but my Beo6 would only recognize them as PC USB connections rather than for charging the device.
The circuitry on the battery is actually the battery temperature sensor. I too thought that this was mean for voltage regulation; but after looking at the wiring diagram, I discovered its actual use.
If you happen to have a universal charging kit with variable voltage; you might be able to dial it in to amount necessary to charge the device.
Page 1 of 1 (2 items) | RSS
