IR eye - BLC NL/ML
Not Answered This post has 0 verified answers | 5 Replies | 2 Followers
Fansastic
The Netherlands
Fansastic posted on Thu, May 21 2020 11:14 AM
Hi all,
Quick question regarding IR eye, can a older version with PL cable be used on a BLC NL/ML converter (with RJ45 connection) using a normal speaker PL to RJ45 adapter? I can’t figure out how to get the IR eye work on de BLC and suspect the adapter trick is not working.
Thanks for sharing your thoughts
BV Eclipse 55 Brass - BL 18 Brass - BL 19 Brass - BL 3 White - BS Moment - BS 2 Brass - BV Horizon 48 - BS3000 - BS 3200 - BS Essence - BL 4000 - V1 40 Black - V1 40 White - BLC NL/ML - H6 -  H4 - E8 Motion - A8 Earphone - Beolit 12 - Beolit 15 - Beoplay A1 Green - Beoplay A3 White
1990
1990 replied on Thu, May 21 2020 12:24 PM
I believe the wiring is different. You have to use the Join version instead of the Play version.
Millemissen
Flensborg, Denmark
This might help
Fansastic
The Netherlands
Millemissen:
This might help
Great this helps! Thanks
Fansastic
The Netherlands
You are correct, I got the join version from my dealer and it is for NL/ML - Essence mk2 - Core.
Fansastic
The Netherlands
New question, anyone know if it is possible to change sound settings for the connected BL’s? If I select A-Setup on Beo4 I see bass-trebbe-loudness but cannot get it to react on anything.
Page 1 of 1 (6 items) | RSS
