Bl3500
Not Answered This post has 0 verified answers | 4 Replies | 1 Follower
Squareheed
Squareheed posted on Sat, Apr 4 2020 5:05 PM
Hi there,my friend has recently introduced me to b&o. I have a bv8 with a pair of bl6000 in my living room.(Sky q is connected to tv also)in the kitchen I have a bl3500 mk 1 which is connected with a master link cable from the tv. I have tried the options out the bv8 manual and the bl3500 manual and although I have a reading on bl3500 when I press sat on beo4 remote I have no sound.......can anyone help...cheers
Stoobietoo
Exeter, Devon, UK
If Sky Q is connected via HDMI you will get no sound via Masterlink. If it is connected via scart you should get sound.
Stoobie
Squareheed
Hi stoobie,thanks for replying to my post. Thought that sky q was maybe the problem.unfortunately sky q box has no scart .
Stoobietoo
Exeter, Devon, UK
You might be able to use something like this to extract analogue sound.
https://www.amazon.co.uk/Converter-Optical-Toslink-Extractor-HD-1080P-Black/dp/B016XMDKXC
Stoobie
Squareheed
Thanks,it’s worth a try and  not expensive.....I’ll get it ordered and give it a try.....thanks again.
Page 1 of 1 (5 items) | RSS
