beovision 7 40 suround sound setup
Not Answered This post has 0 verified answers | 3 Replies | 0 Followers
weejoe
weejoe posted on Fri, Apr 3 2020 11:49 PM
Hi
I have a beovision 7 40 and with a 7.4 centre speaker and beolab 6000 for fronts.
I also have a beo center 9500 and some passive speakers I was looking to see if I could use rca plugs to make this work the rear speaker signals for right and left are 7 pin plugs. can I use 7 pin to single rca and then a rca adapter to the aux in on the beo centre?
DrDimitris
Greece
I think it is doable but you need to check with the specialist on cables Steve at Sounds Heavenly.
https://soundsheavenly.com
He will for sure help you and provide you woth the right cables for your setup.
Dimitris-
stefan
200 miles from Struer
stefan replied on Sat, Apr 4 2020 11:09 AM
I don`t think this will work.
BV7-40 must be configured to 5.1 setup. To configure Powerlink sockets, it is necessary, that the BV7 will detect a Powerlink product connected to the socket (Beolab speaker or Beo amplifier like MCL2P).
The simple way would be, masterlink your BC 9500 and BV7-40, connect an MCL2P to BV7-40 PL output, connect your passive speakers to MCL2P, set your BC9500 to A.OPT 0, set your BV7-40 to V.OPT 2 - that`s it.
You will need a Beolink converter 1611, an 7pin Audio Aux Link cable, a Masterlink cable, an MCL2P amp - available cheap second life..
Now you have the `classic`0-2 AV setup. When listening to BC9500, the BL6000s will automatically activated (stereo), when watching TVV you can activate BL6000 + center (BL7.4) or all 5 speakers (SPEAKER mode 5).
And you can add a sub like BL2/11.
Welcome to Beoworld.
Stefan
leosgonewild
Helsinki, Finland
Silver Member
Buy Beolabs for the rear instead.
Page 1 of 1 (4 items) | RSS
