Beolit 12/15/17
This post has 9 Replies | 1 Follower
steve1977
Posts 911
steve1977 Posted: Sun, Mar 29 2020 3:26 PM
Am i the only one who’d love to see a new Beolit? Same form factor as the 12/15/17, but equipped with ac wifi and airplay-2. Should be a low hanging fruit for b&o. Anyone heard rumors about some device like this?
leosgonewild
Helsinki, Finland
Posts 2,361
Silver Member
Did you see the upcycle that me and Tuomas did?
We took a Beolit 12 apart and replaced the WiFi card/airplay module with a Google mini.
You can get a Beolit 12 fairly cheap these days.
StUrrock
Posts 995
StUrrock replied on Sun, Mar 29 2020 7:52 PM
Ver cool. Would love to see the step by step instructions.
The Beolit 12 sounded great, but the wifi/airplay card was just pants.
steve1977
Posts 911
steve1977 replied on Mon, Mar 30 2020 1:14 AM
Agree, this is really cool! I even have a much beloved beolit 12. Unfortunately not a fan of google chrome. If possible to replace for a better wifi card abs get AP2 to work, this would be fabulous.
leosgonewild
Helsinki, Finland
Posts 2,361
Silver Member
If I get a hold of another one, I will make instructions.
matador43
Posts 1,362
matador43 replied on Mon, Mar 30 2020 9:04 AM
steve1977:
I've tried to "airplay convert" various B&O devices, including portable ones. In that cas the main problem I ran into was Power : Aiport bases are main powered and even if you want to tear it down, there's still at least 2 different power voltages with would not make it an easy job.
leosgonewild
Helsinki, Finland
Posts 2,361
Silver Member
Did you try to fit an airport express inside?
matador43
Posts 1,362
matador43 replied on Mon, Mar 30 2020 11:49 AM
___:
Not into a Beolit 12. And generally not "into" devices because i didn't wanted to harm the original devices.
I have "Airplayed" a Beosystem 10. I wanted to make it run fully on batteries but I didn't managed to:
https://forum.beoworld.org/forums/t/36351.aspx
And a Beoplay A2 wich I would have liked to power the Airport base from the USB, to have the wall socket free to charge the A2. But I also didn't get it:
https://forum.beoworld.org/forums/t/38833.aspx?PageIndex=2
leosgonewild
Helsinki, Finland
Posts 2,361
Silver Member
I have an airport express (with airplay 2) that runs of usb power.
I tried to power it from the Beolit 12, but it gives some kind of surge to the audio signal/aux cable.
matador43
Posts 1,362
matador43 replied on Thu, Mar 25 2021 4:22 PM
Yes, they're a lot of hacks to power the Airport express from usb or even à 9v battery.
From memory you need two voltages: 5v and 3,3v.
I tried the hack with the duck power board: 5v directly from USB power and 3,3v via the duck power board.
it did work for a while. after some weeks the AE was fried (not the duck board).
I now have a second AE that died after being in the bathroom for maybe too long; no power at all.
I should open it and plays with the duck board again, but those boxes are painful to open so at the fifth confinement maybe…
Page 1 of 1 (10 items) | RSS
