Harmony software
Not Answered This post has 0 verified answers | 50 Replies | 3 Followers
gysse2004
Hellerup
gysse2004 posted on Wed, Mar 25 2020 3:35 PM
New software update, fixed light diode disappears during audio mode, shows metadata for radio on top for 2 min now, instead of on the left hand side. Much nicer 😎 also gives coverflow when playing Chromecast.
Peter
Beovision eclipse 65, Beolab 50, Beolab 18, Beovision 11, Beolab 3, Beolab 2, BeoVision 10, MLGW, BeoLink converter Nl/Ml, Beosound 5, BLGW
HH1971
It is frustrating to see that Bang&Olufsen does not change / enhance it.
gysse2004
Hellerup
New software 3.0 for Hamony, don’t now what’s new..
Audio
Audio replied on Tue, Sep 15 2020 8:58 PM
Is it possible to stream the sound of TV life program from a Beovision Harmony in sync to a NL speaker e.g. Beosound 35?
Similar as it was possible via Masterlink. I would like to listen to my Beosound 35 at the kitchen when e.g. news is running in the living room on a Beovision Harmony.
Hiort
Sweden
Hiort replied on Wed, Sep 16 2020 5:34 PM
Audio:
Is it possible to stream the sound of TV life program from a Beovision Harmony in sync to a NL speaker e.g. Beosound 35? Similar as it was possible via Masterlink. I would like to listen to my Beosound 35 at the kitchen when e.g. news is running in the living room on a Beovision Harmony.
Absolutely
Dyssegaard
Copenhagen, Denmark
Audio:
When I stream the sound of a live tv program from my Eclipse to my Beoplay M5 over NL, the sound on the M5 is delayed and thus out of sync with the Eclipse.
I assume, that this will be the same on the Harmony ...
Best regards - Dyssegaard
Living room: Beovision Eclipse 55, Beolab 3 / R1 (back), Beolab 2 / R1 (sub), AppleTV 4K. Bedroom: Beovision 11-40, AppleTV 4. Home office: Beoplay M5. Kitchen: Beoplay M5. Travel: Beoplay H8, Beoplay A1. NAS: WD My Cloud Home / Plex DLNA Server.
andy_js
Englandshire
There’s an option on the BV11 to adjust the network delay which can be used to fix that. I would hope the new LG based sets have something similar.
Alsfeld
andy_js:
I just tested it. Similar situation here, when I connect my Beosound 1 or Beoplay M3 to my Beovision Harmony I have a heavy delay listening to TV (no problem listening to Radio at the Harmony). But I still use the standard sync settings of 50 / 1000 msec.
@andy_js: What network delay settings you are using, to have it in sync?
gysse2004
Hellerup
New 3.1 software out
Aussie Michael
Melbourne, AU
Dyssegaard:
I assume, that this will be the same on the Harmony ... Best regards - Dyssegaard
Living room: Beovision Eclipse 55, Beolab 3 / R1 (back), Beolab 2 / R1 (sub), AppleTV 4K, Bedroom: Beovision 11-40 , AppleTV 4 . Home office: Beolit 12, Kitchen: Beoplay M5 . Travel: Beoplay H8, Beoplay A1. NAS: WD My Cloud Home / Plex DLNA Server.
You adjust the audio delay in the app under M5 and then it will be in sync
I had that when i got the A9 years ago and as soon as I changed it, never an issue anymore.
Dyssegaard
Copenhagen, Denmark
I have found this useful document at B&O Customer support:
https://bogo.custhelp.com/ci/fattach/get/1304261/0/filename/Multiroom+-+october+2017+-+PDF+handout.pdf
At page 10 it is stated for Eclipse, that sound is delayed in link rooms for all video sources.
At page 2 it is stated for BV11 and Beoplay V1, that sound will be in sync in link rooms for all video sources.
Both statements reflects my observations with my Beoplay M5 connected to Eclipse or BV11 via NL.
However, since the document is dated October 2017, there is no information regarding the Harmony.
Millemissen
Flensborg, Denmark
I am pretty sure,,that what you read there about the Eclipse, will be the same for the Harmony.
I am not aware of a solution there.
kawo
kawo replied on Sun, Oct 11 2020 11:34 AM
Unfortunately since the last update I have several glitches with the Harmony. After I connected a external STB box with PUC control and the recent software update I can't control volume any more, only when you select the STB HDMI port at the sound center it comes back for all sources. also the B&O app does not start always, only disconnect power plugs will help.
Also sometimes no sound at all, also only disconnect of power helps.
Anybody similar experience? Need to call my B&O shop on Monday
Alsfeld
Is it possible to switch from PUC to CEC to control the Apple TV?
The advantage would be that the additional PUC cable and the infrared transmitter are not anymore necessary.
But how?
Does CEC work on the Beosound Harmony Soundstage HDMI (A to D) connectors (how do I enable CEC) or only on the LG TV HDMI (1 to 3) connectors directly on the LG TV on the left side?
Are there any disadvantages?
gysse2004
Hellerup
New Harmony software 4.0.4 out
Peter
Fansastic
The Hague, The Netherlands
Recently I experience a problem with Youtube. When watching YT and turning of the Harmony it first starts to close down but in a second or so the tv switches back on showing LG icon, the speakers open again, the tv box powers up and sound is coming from tv instead of sound center.
Turning it down again, all is fine.
Seems an sync issue with the LG apps and sound center.
Anyone else having this issue?
Page 3 of 4 (51 items) < Previous 1 2 3 4 Next > | RSS
