Lg Oled tv + bang olufsen speakers
Not Answered This post has 0 verified answers | 18 Replies | 4 Followers
Andrea
Buonomo
Andrea posted on Sun, Mar 15 2020 10:13 AM
Configuration
Lg Oled 65 2019 with wisa ready , 4 beolab8000 ( 2 fronts, 2 rears) , beolab 2 sub, beolab 10 (central)
I bought axiim link wisa and 6 beolab receiver 1. I connected my lg tv with wisa connection to all the speakers. It works
The sound quality is ok, but when i connect a beosystem the quality sound is much better.
I would like to buy a beosystem 4 and connect it using trasmitter 1 and receivers to speaskers.
the question is :
how can i send sorround input from my Lg Tv to a beosystem 4 ? Is it possible? How is the quality sound?
do you have any other advise?
Esax
Esax replied on Mon, Mar 16 2020 6:26 PM
I had that ide to. I am going to test a couple of things when my tv arrive. If it does with corona everywhere.
Beovision 7-55 MK1 red, Beolab 10 red. Beolab 50, all black. Beolab 17 broken ice. Beolab transmitter. Apple tv4 and apple express 2.
Andrea
Buonomo
Andrea replied on Mon, Mar 16 2020 7:48 PM
In few days i will try with a beosystem 3 or 4 , i ordered a converter from optical to coaxial. I ‘ ll let you know you if results are good.
Andrea
Buonomo
Andrea replied on Sat, Mar 21 2020 1:11 PM
Hi Esax,
i tried but it is not possible to have a sorround system with 4K image.
at the moment i ‘ m asking around about Almando sorround Wisa .
Andrea
Mikipidia
ONLINE
With either almando or axiim it will obviously sound different as it doesn’t know what speaker are connected (type) and it’s capabilities that are attached to it, as in the speaker profiles. It just takes a, let’s say, bl17 and treats is as a generic speaker. Only b&o has the specific presets preloaded, but with both axiim and almando you can make presets per channel, it’s more work obviously but b&o doesn’t have a 4k capable beosystem atm.
In that way there is little difference between axiim and almando. The axiim looks a lot easier to me though, a mate of mine has done it with axiim and has had great results honestly.
New: Beovision Harmony, Beolab 50's, Beolab 18's, Beolab 17's, Beolab 3's, Beosound 9000 mk3, Beosound Stage & LG, Beosound 2, Beoplay M3, Beoplay A1, Beoplay H4 gen 2, Beoplay E8 3.0
Mikipedia on YouTube (finally Stick out tongue )
https://www.youtube.com/c/Mikipedia
Old: Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Thomas
Norway
Thomas replied on Sat, Mar 21 2020 2:19 PM
Hi
is it possible to use an HDMI audio splitter, put the audio signal to beosystem 3/4 and video signal to the LG?  This swhould work i think...
Format 0  😀😎
Andrea
Buonomo
Andrea replied on Sat, Mar 21 2020 2:43 PM
Thank you for the advise , the sound difference is impressive between axiim and beosystem.
i would buy a beosystem 3 mk3 or 4
is it possible to send audio from my tv to beosystem 3 or 4 for sorround audio?
I have 4 beolab 8000 (fronts and rears)
beolab 2 sub
beolab 10 center
Andrea
Buonomo
Andrea replied on Sat, Mar 21 2020 2:44 PM
Hi
HDMI audio to beosystem does not work.
andybandy
You can only put a monitor screen to the Beosystem 3 or 4. so connect a hdmi -  DVI to system 3 or HDMI - HDMI for montior on system 4.
So only picture will get true there, so you need to connect a google chromecast HD or apple tv true beosystem 3 and 4, use it with puc and control it whole with Beoremote one :)
That will be your best solution.
Cheers, Andreas
OldJack
Split
Andrea:
Hi
Yes,it does.I am using  Oppo udp203 ,one output into 4k tv, audio ouptut into beosystem3 (mk3).You can use  hdmi splitter from any source,the same way.
Beogram 6500 MMC2,Beosound Ouverture,2xBeolab 8000,2xBelolab 4000,Beolab 2,Beolab 7.2,Beo4 navi, 2xBeocom2,Serene,Beosystem 3 mk3,H6 2nd gen,Earphones E8,A8,A9 keyring,Beoplay A1,Bottle opener,Beoplay A2 active(thanks Botty)Wine Set(thanks Botty),4Ktv Samsung 55'',Beolab 7.1 with 42''Panasonic plasma,,Oppo udp-203, LinTronic.
Andrea
Buonomo
Andrea replied on Sat, Mar 21 2020 3:41 PM
After 3 weeks I found the solution , a bang olufsen technician helped me.
i use a optical to coaxial converter.
sorround works.
On the following Tuesday he will come and install beosystem mk3.
if somebody needs I will make a video I can sent you if you like, and you can post on your YouTube channel or you can use it.
andrea
Mikipidia
ONLINE
Hi andrea, sure that would be lovely! I’d be happy to have that on my channel for others to see!
My email is: mikipedi4@gmail.com
Big Smile
Michael
Stoobietoo
Exeter, Devon, UK
Yes, please make a video and a list of everything you needed to make this work.
Thank you
Stoobie
Peter
Sweden
Peter replied on Wed, Apr 8 2020 12:01 PM
Hi Guys!
This is an interesting thread as I am looking into this as well.
Another related question:
- Are you using two remotes, one for the LG TV and one for the B&O setup?
- I understand there is a B&O app to download from the LG Store to control the LG TV with a BeoremoteOne bluetooth remote, but do you know if it at the same time can handle older B&O kit with IR simultaneously? I heard from a dealer that it takes a lot of "button pressing" to use the BeoremoteOne BT, switching between the LG TV and fx. a BeoCenter sound system..
Any experiences with that?
Peter
Beovision 7-40 Mk VI, Beovision 3-32, Beovision AV9000, Beovision AV5, Beolab 8000, 6000, 5000, 3000, 2000,  Beocenter 2300, 9000, Beocenter 2, DVD1, DVD2, Beogram 3300, LC2, Beolit 12, 3 x AppleTV
Aravind Viswanath
Sydney Australia
Another option to the Beosystemwhich my dealer is suggesting is to get the new B&O sound bar. Dealer is saying that I can connect this to any TV thought the Samsung OLED can control through the Beo remotes.. and can connect through to my Beolabs...
haven’t had a chance to go into the dealer with all the COVID lockdowns in place and not sure if all the speakers listed will connect but on the face of it may be a viable alternative?
Page 1 of 2 (19 items) 1 2 Next > | RSS
