Beosound Core Deezer HIFI
Not Answered This post has 0 verified answers | 44 Replies | 1 Follower
jg1976
jg1976 posted on Fri, Feb 28 2020 5:10 PM
I have just been in contact with Bang & Olufsen support regarding question if Beosound Core supports Deezer HIFI subscription, FLAC format (16-bit, 1,411 Kbps).
I received following answer:
"The built-in Deezer app on the Bang & Olufsen application only supports normal Deezer however via the Deezer app you can stream Hifi using Airplay 2 or Chromecast to the Beosound Core".
I definitely want the HIFI option (I do subscribe on it.. ) since I have connected beosound Core to my Beolab 5 optically.
Anyone else has other information about this or if it is planned/or even possible due to an update for Beosound Core?
jg1976
jg1976 replied on Fri, Feb 28 2020 5:26 PM
I guess this will be of big interrest for many beo-sound-enthusiast out there.. To have the possibility to play with best deezer quality available..
Hiort
Sweden
Hiort replied on Fri, Feb 28 2020 5:42 PM
That was really strange .... not supporting Deezer HiFi.
All other B&O devices do that.
Can anyone with a Core and Deezer HiFi subscription confirm?
Beobuddy
Utrecht, The Netherlands
Beobuddy
jg1976:
...since I have connected beosound Core to my Beolab 5 optically.
Interesting setup. Did you connect both powerlink (RJ- Powerlink Din) and optical (to COAX digital) simultaniously? Or just optical and another option (1 ) on the BL5?
AFAIK the digital input from the BL5 was only actived when "CD" command was send through the powerlink. But maybe that is only valid when you use the option 0 (factory setting) is used.
Razlaw
Razlaw replied on Fri, Feb 28 2020 8:12 PM
I have Deezer HIFI and a Core connected to 50s. I thought I was getting HIFI. This makes me wonder. I will try the Deezer app and airplay and see if I can notice a difference.
Beolab 50s Beolab 9s Beolab 12-3s Beolab 1s Beolab 6000s 2 pairs Beolab 4000s Beovision 7-55 Beovision 10-40 Beoplay V1 32 inch Beovision Avant 32 inch Beosound 1 (CD player) Beosound 3000 Beosound 5 Core Essence MKII Beoplay M5
jg1976
jg1976 replied on Fri, Feb 28 2020 8:35 PM
Beobuddy: Yes, I read this forum back and forth. But when I came to the solution it was just perfect for me:
Having a masterlink system (cat7 wired throughout the house). A beolink converter nl/ml in the office created another light-zone but also made it possible to add a core in the living room.
Deezer is set to CD in my system, making beolab 5 to automatically listen to optical port, but I can still, and at same time listen to the same source in any other zone in my house (11 zones Unsure).
This was just the perfect solution, when sitting in my livingroom ”listening” to best audio on ”best” beolab 5 speakers I wanted to use coax input of course, but also having Deezer HIFI.
Therefore I was little dissepointed once I received the reply from b&o.. Mayby they were wrong and one can only hope so... Or if there will be an update in very near future..
See my livingroom setup here:
jg1976
jg1976 replied on Fri, Feb 28 2020 8:36 PM
Razlaw: yes, please give your feedback to this.. most appeciated..
Razlaw
Razlaw replied on Sat, Feb 29 2020 12:49 AM
My initial impression is that the sound is better from the Deezer app. Will do some more listening tomorrow and see if my opinion is the same.
Mikipidia
Have someone else switch sources for you, that way you don’t “know” what’s playing, hifi or not.
New: Beovision Harmony, Beolab 50's, Beolab 18's, Beolab 17's, Beolab 3's, Beosound 9000 mk3, Beosound Stage & LG, Beosound 2, Beoplay M3, Beoplay A1, Beoplay H4 gen 2, Beoplay E8 3.0
Mikipedia on YouTube (finally Stick out tongue )
https://www.youtube.com/c/Mikipedia
Old: Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Razlaw
Razlaw replied on Sat, Feb 29 2020 1:16 AM
I do need to that. First will have to train someone how to do that.
danielshen
Dear,
May I know how to set "Deezer is set to CD in my system, making beolab 5 to automatically listen to optical port"? Such setting is in the B&O APP?
Can you give me a screenshot for the Deezer -> CD setting? Many thanks!
Daniel
jg1976
jg1976 replied on Sat, Feb 29 2020 6:27 AM
Danielshen: I set it via beolink converter nl/ml. CD-source is ”Music” equal to start Deezer..
jg1976
jg1976 replied on Sat, Feb 29 2020 6:52 AM
Razlaw: My initial thought for writing to B&O, was that I felt a "different" in audioquality when playing in my office versus livingroom.
Setup in office: Beolink Converter NL/ML, Imac with Deezer app (can handle Deezer HIFI), Beosound 3 connected from 3,5mm output from Imac to the converter line-in...
Millemissen
Flensborg, Denmark
Mikipidia:
....and (volume) level match precisely - best using a soundmeter of some kind.
Even a slight difference in the volume level can fool you to think that one is better or worse than the other.
Page 1 of 3 (45 items) 1 2 3 Next > | RSS
