Beovox 5700/5702 opinion ( I started my renovation )
Not Answered This post has 0 verified answers | 42 Replies | 1 Follower
Martynka
Poland
Martynka posted on Tue, Feb 18 2020 9:47 PM
Can you give me some opinion about HT5700/5702 with passive radiator. It's really hard to find something about it. Only short note in Beocentral and here... but when I try to find something about M70 , M75, M100 I can read that 5700 or 5702 was one of the best sounded Beovox.
Hmmm... Hmm
Marcin
BeO is like a good wine - the older the better...
Martynka
Poland
@Dillen, do you have my crossovers scheme or it is the same but with other value ??
Martynka
Poland
Martynka replied on Wed, Mar 25 2020 11:48 PM
I found it, 5700 (6229) and 5702 :
and one more time 5700 (6253) to compare:
Martynka
Poland
My 5702 blog next chapter Big Smile
I checked in crossover simulator both types:
- this is frequency response from scheme 6253 type:
and 6229 type:
and for me something is wrong with hitones. I remeber, when I rebuilded crossovers in my 104aB I connected wrongly ( - ) T27 tweeter wire to ( - ) line and I not heard hitones. Tweeter was inverted, after reconect tweeter ( + ) to line ( - ) everything sounded perfect.
Remembering this fact I invert tweeter polarity in Xsim and:
and it look better.
I looked inside my 5702 (crossover 6229 type) and BeO done the same like me in simulator. Violet tweeter wire ( + ) is connected with black woofer wire ( - ) and blue mid ( - ) wire.
it means that tweeter polarity on 6229 scheme is wrong.
I chcecked 6253 wiring too and blue mid wire ( - ) is connected with white hitones wire ( - )
Here is a comparison of the frequency characteristics of both crossovers in one diagram:
red - 6229
blue - 6253
It seems that 5700 (6229) and 5702 sounds better than 5700 (6253), so why did BeO change the crossovers ??
In "Stereo review" from 1972 we can read that: "...The system impedance was between 6 and 25 ohms" I check it and here we have impedance difference:
red - 6229
blue - 5253
In my opinion Bang&Olufsen put new crossover inside to make life easier for amplifier. New crossover decrease impedance peak but it decrease a little frequency response.
Martynka
Poland
I done few simulation with my 6229 type crossover. When I put 50uF capacitor in place of 20uF. I decrease impedance peak and increase little bit frequency response in low frequencies:
red - 20uF capacitor
green - 50uF capacitor
hmmm... I know , it is not DIY section but do you think it will be hearable difference ??
Dillen
Copenhagen / Denmark
ONLINE
Dillen replied on Thu, Mar 26 2020 7:26 PM
Please keep in mind, that the cabinet, damping materials etc. are also components in the whole speaker.
It can have a huge influence.
Martynka
Poland
Yes, it's only simulation. Now I put new Elko Jantzen capacitor because I'm still waiting for package from U.K.
I am curious about the effect on new capacitors because in Beolab I have already changed the output capacitors.
Martynka
Poland
Because I still wait for Alcap I made temporary crossover with ELKO/Jantzen:
8uF -> 8,2uF
20uF -> 22uF
75uF -> 82uF
Like I wrote in Beolab thread:
Everything I did before improved the bass, now I opened up the highs. But In the same time I changed power capacitor in Beolab 5000 and I don't know witch caps opened up this.
P.S. Package from FalconAcoustics is in Poland. A should get Alcap caps soon.
Dillen
ONLINE
Dillen replied on Fri, Mar 27 2020 8:30 PM
The output series capacitor is so large in capacitance, it won't have a lot of influence on the treble response.
It will almost certainly have improved the damping factor though.
Martynka
Poland
It means that all this changes are from Beolab after replaced power caps.
Martynka
Poland
Martynka replied on Mon, Mar 30 2020 10:55 AM
6257 really exist  !!! Smile
https://www.dba.dk/hoejttaler-bang-olufsen/id-1065169896/
Hi - Celestion HF2000
Mid - Celestion HF500
Low - Seas 33F-WK
Dillen
ONLINE
Dillen replied on Mon, Mar 30 2020 12:01 PM
Martynka:
Low - Seas 33F-WK
Yes, as I already showed you earlier in this thread!!
Martynka
Poland
Martynka replied on Mon, Mar 30 2020 12:06 PM
Yes, you show me photo, I show you pair for sale Big Smile
Tell me, what material BeO used for internal speaker wires in vintage Beovox. Tin covered cooper ??
Martynka
Poland
Martynka replied on Tue, Mar 31 2020 10:23 PM
And last change - Alcap on board:
Page 3 of 3 (43 items) < Previous 1 2 3 | RSS
