Beoremote One Battery box
Milton78
Stockholm, Sweden
Posts 39
Milton78 Posted: Mon, Feb 17 2020 8:57 PM
This might be an odd question, but this evening I managed to ruin the battery box in my Beoremote One BT during a battery change. The little metal bracket broke off completely (which of course has ruined my night in addition to making the remote useless). Now, my question is - do you know if I can obtain a new battery box to replace the one I broke, rather than getting a completely new remote?  Reason for asking here is that my local dealer has closed up so that route is closed.
TWG
Posts 1,632
ONLINE
TWG replied on Mon, Mar 30 2020 3:33 PM
Can you share a photo of what's broken? Is it only the metal sheet contacting the batteries?
In this case you could order some thin e.g. copper sheet and use a tinsnips to cut it out (nearly) exactly like the original contacts of the battery box, bend it accordingly, fit it inside your remote and eh voilà: Battery box working again.
bhaiterabhai
Posts 1
I did and he noticed the same on the remote in store and was going to talk with B&O but I havent heard anything after that. It annoys me that it is sharp because I scar myself because of it sometimes too and it´s not nice to scratch your danish furniture either. I´m just happy I don't have small children.
shareit vidmate
Griebel
Posts 409
Griebel replied on Fri, Apr 17 2020 8:45 AM
Milton78:
Same happened to me. Contacted B&O support to have the battery holder replaced. I’m waiting...
Beozip
Posts 355
Beozip replied on Sun, Aug 1 2021 7:38 AM
You can buy the battery box as a spare part like this ....
https://www.ebay.de/itm/284232359912?hash=item422d919fe8:g:v3EAAOSwLpNgXKQu
good luck
Page 1 of 1 (5 items) | RSS
