Beoremote One Battery box
Milton78
Stockholm, Sweden
Posts 39
Milton78 Posted: Mon, Feb 17 2020 8:57 PM
This might be an odd question, but this evening I managed to ruin the battery box in my Beoremote One BT during a battery change. The little metal bracket broke off completely (which of course has ruined my night in addition to making the remote useless). Now, my question is - do you know if I can obtain a new battery box to replace the one I broke, rather than getting a completely new remote?  Reason for asking here is that my local dealer has closed up so that route is closed.
TWG
Posts 1,632
TWG replied on Mon, Mar 30 2020 3:33 PM
Can you share a photo of what's broken? Is it only the metal sheet contacting the batteries?
In this case you could order some thin e.g. copper sheet and use a tinsnips to cut it out (nearly) exactly like the original contacts of the battery box, bend it accordingly, fit it inside your remote and eh voilà: Battery box working again.
bhaiterabhai
Posts 1
I did and he noticed the same on the remote in store and was going to talk with B&O but I havent heard anything after that. It annoys me that it is sharp because I scar myself because of it sometimes too and it´s not nice to scratch your danish furniture either. I´m just happy I don't have small children.
shareit vidmate
Griebel
Posts 409
Griebel replied on Fri, Apr 17 2020 8:45 AM
Milton78:
Same happened to me. Contacted B&O support to have the battery holder replaced. I’m waiting...
Beozip
Posts 355
Beozip replied on Sun, Aug 1 2021 7:38 AM
You can buy the battery box as a spare part like this ....
https://www.ebay.de/itm/284232359912?hash=item422d919fe8:g:v3EAAOSwLpNgXKQu
good luck
Page 1 of 1 (5 items) | RSS
