Beogram 4500 owners manual
Not Answered This post has 0 verified answers | 4 Replies | 1 Follower
f5434964
Austria
f5434964 posted on Mon, Feb 17 2020 6:30 PM
Hello!
Is there a more sophisticated owners manual than the one which could be found online? I just find the one with 6 pages (setup etc.)...there is nothing who to operate the Beogram...
special needs: mounting mmc - just plug and play? anything that has to be done in a given way?
the other functions should be self explaining...
best regards
Elmar
PS I do not mean the service manual
lawrencejmcook
I think you’re looking for the Beosystem 4500 user guide on the beoworld site.
See page 6 et seq.
Lawrence
f5434964
Austria
thanks for the hint
as I have to mount the stylus on my own - is this just plug and play? Can/Do I/have to anyhow lift the tonearm?
thanks in advance
best regrads
Elmar
lawrencejmcook
Hi Elmer,
The whole cartridge is plug and play:
1) Check that the stylus guard is lowered, i.e. protecting the stylus.
2) Holding the tonearm still with one hand, insert the cartridge into the end of the tonearm.
3) Adjust the stylus pressure using the sliding control near the rear (right hand side?) of the tonearm.
From memory: 1.5g for MMC5 and 1.0g for MMC1. You should be able to find the specs on BeoWorld product info pages.
4) Carefully raise the stylus guard to its “parked” position (it should click into place), to expose the stylus to the record.
Pick a record and enjoy!
Lawrence
f5434964
Austria
thanks! Did work fine!!!
Best regrads Elmar
Page 1 of 1 (5 items) | RSS
