Broken Charger tip on BeoCom 2 device.
Not Answered This post has 0 verified answers | 3 Replies | 0 Followers
TarikG
TarikG posted on Thu, Feb 13 2020 3:01 AM
Hello,
I have two Beocom handsets. The tip that plugs into the wall socket has broken off one end, exposing the electrical connections.
Anyone know how i can find an easy solution to fixing this?
loureed5
loureed5 replied on Thu, Feb 13 2020 10:49 AM
I would speak to Steve @ Sounds Heavenly -he's a B&O specialist and maybe able to provide you with a suitable cable.
Regards
Noel.
w5bno123
London
w5bno123 replied on Thu, Feb 13 2020 12:21 PM
That’s a job for your local B&O dealer to service for you.
Guy
Buckinghamshire
ONLINE
Guy replied on Thu, Feb 13 2020 1:09 PM
TarikG:
If you're referring to the two red connectors, then they look like car type crimp connectors and were probably used to reconnect the wires after passing through a wall or hole in cabinet.  If the part connected to the handset has exposed wires it should be straightforward to reconnect using similar crimp connectors or even some terminal block. If you know someone who is handy with a soldering iron then they could be soldered and then covered with heatshrink. You just need to observe the colours of the wires.
Page 1 of 1 (4 items) | RSS
