Beosound 5, SW update problem
Not Answered This post has 0 verified answers | 17 Replies | 0 Followers
marexy
marexy posted on Wed, Feb 5 2020 7:57 PM
I have a weird example of a bug on Beosound 5
After the factory restore, I can no longer update SW.
It says I can't update SW because there is no connection to the server.
Going into the settings shows me no internet connection.
N-RADIO working  and finds many stations, but without logos.
What's the problem?
Weebyx
Denmark
marexy:
What's the problem?
It is "standard" that settings will show "no connection", this is something you can ignore, if it can load the radio stations, then you have internet connection. The logos takes a long time(days) to be completely loaded, and I have also seen there are some XML problems in the log files. Some time ago, other people also talked about the update server not being available, but it was active again after some days. Maybe B&O have decided to shut down the server again ?
It is understandable that they discontinue products, but a "internet product" like BM5, must not have problems with SW update and stations afterwards. It costs a lot of money, and should be expected to continue to have access to backend for a very very long time in my opinion. It cannot cost B&O that much money to have that backen running.
My fear is that they have no people, that knows anything about those servers anymore. Which is kind of worse.
Keep the BM5 running for some days, and see if radio covers appear over time, and keep trying the SW update.
/Weebyx
marexy
Thanks for answer :)
I have service tool but can not confirm that is ok..as i loaded from link here on forum.
Did any of you try that ...is it working ?
Have save that SW on the USB key ..but nothing happened..i can not see USB key if i go to Beomaster 5 service mode.
Maybe i did somethin wrong when copy SW to USB key ?
Weebyx
Denmark
marexy:
Maybe i did somethin wrong when copy WS to USB key ?
The USB stick should be created with the ImageUSB program, you should not just copy files to the USB.
/Weebyx
marexy
Hi
i done the ImageUSB program key ..but no luck :(
i can go to service mode..i can see USB key ..bu can not enter screen for DHH or bios update..
any hint what is not ok ?
Weebyx
Denmark
You need to attach a external keyboard, and have the USB inserted, then shut down BM5, and hold down ESC or F12(cant remember) while booting, this allows the system to boot from the USB.
It cannot be used in service mode. It is only for booting of the system from USB.
/Weebyx
marexy
marexy replied on Sat, Feb 8 2020 10:15 AM
Hi
Thanks for help..
I did all that no without success :(
but..Some good news :)
I manage to update SW to latest version..
Last night BS5 connected to server and wauu...now working but not in full.
N-RADIO is OK..can see logo from net. radio stations.
N- music is working.
Now only problem is :  that with BEO4 remote I can control it remotely sometimes and sometimes not.
Can change the volume a few times, switch between functions and then a few seconds later it does not work anymore :(
and than ...minute later ..is ok again..hmmm
and... I can't wake up  BS5 with a remote control from ST-by.
DAMN... :(
Weebyx
Denmark
Weebyx replied on Sat, Feb 8 2020 12:31 PM
marexy:
Hi
Thanks for help..
DAMN... :(
Are you sure its role and option is set up correct ? Is it standalone, or connected to something via masterlink ?
The BM5's has trouble with the mainboard, maybe your is about to go bad ?
I have just read the service manual. You should shutdown the BM5 from service menu, or disconnect from mains. Install the USB with service tool and keyboard in USB port, connect power, and keep pressing ESC while you start the BM5 again. This should give you the boot option of selecting the USB drive for boot.
It worked like a charm on the BM5 I had.
/Weebyx
marexy
Hi
yes..i have new main board and yes.. it is standalone..AM option 1 as it should be,
But if i do as you suggest:  shutdown the BM5 from service menu, or disconnect from mains. Install the USB with service tool and keyboard in USB port, connect power, and keep pressing ESC while you start the BM5 again. This should give you the boot option of selecting the USB drive for boot.
i can see my Toshiba USB key in BM5 system, but i can not go further into the service options. So it's a bug in the USB stick as it is not original one.
I do not have another or is not correct software on USB stick.
Weebyx
Denmark
marexy:
Hi
What do you mean "i can see USB in BM5 system" ? When pressing ESC during power on, the mainboards BIOS should show you a list of devices it can boot from. There you should select the USB stick. You cannot use the stick in the windows xp mode of BM5 once it is booted up.
Could you take a photo of the boot select screen after you press ESC from boot ?
/Weebyx
marexy
Hi
that is what i see..
i select Toshiba + ENTER
marexy
enter....and than ,that warning on screen...anain enter ..than BS5 goes to usual operating mode
Weebyx
Denmark
marexy:
That looks weird. Where did you get the service tool ?
Have you tried with another USB stick ?
/Weebyx
Weebyx
Denmark
marexy:
Can you send me an email ?
/Weebyx
marexy
hi Weebyx
You have mail :)
Page 1 of 2 (18 items) 1 2 Next > | RSS
