Beo 4 Repainting
Not Answered This post has 0 verified answers | 12 Replies | 1 Follower
JKW TAYLOR
Nederland
JKW TAYLOR posted on Sat, Feb 1 2020 6:23 PM
How do you repaint a Beo4 ??
I have searched the forum, and cant find anything ? most Beo4 body's chip or get scratched, is there a workshop on how to repaint them ??, do you have to strip them back to bare metal ?
Ken
bramble
I have always used hammerite ( non hammered )... works and lasts
Also better Finnish when the surface is prepaired ..medium grade paper
Beovision 7 40 mk 5 ,beovision 6x3,   beosound 3000, beogram 3300 , 2 x lc2, 2 x beocom 1401, beocom 6000 x 2,  5 x beo4,
, 4 x beolab 4's, form 2, h2, a2,a1 and a beolab 2 😀😀
JKW TAYLOR
Nederland
Paint brush or spray ? Have you done many of these remotes ?
Ken
bramble
Spray is best ...a bit of an issue getting the battery terminals clear from the case of the remote ...just take care.
When you have the case, wire wool and gently remove any loose paint
Then just hang and spray about 3/4 light coats will do and allow 24/36 hrs for drying
JKW TAYLOR
Nederland
I have a large section on the side that is bare metal, how can i fix this, or do I have to strip the side back to metal and repaint the side first, so that I get an even coat on the whole body.
Ken.
bramble
Just take it back to bare metal with a paint stripper then wash and dry ready for paint.
JKW TAYLOR
Nederland
Thanks,
Ken
Have you got a Beovision 7-40mk5 ? Im looking for the Manuels ?
JKW TAYLOR
Nederland
Strange that no one else on the forum has ever painted a Beo4 ?
Ken
Beozip
ONLINE
not here but there is a dealer on ebay ....
https://www.ebay.de/itm/Bespoke-Bang-amp-Olufsen-b-amp-o-beo4-Fernbedienungen-Charakter-Print-Titan-12-/303239644703?nma=true&si=9V2X3oH7AlnP1JEWdUoBlny2WI8%253D&orig_cvip=true&nordt=true&rt=nc&_trksid=p2047675.l2557
good luck
JKW TAYLOR
Nederland
Still no dealer thats ever repainted or touched up a Beo4 ?
Strange, maybe it was cheaper for them to buy a new body ?
Ken
matador43
ONLINE
You know, let's have a different approach: Stop seeing it as a B&O pricey icon and just see it as a piece of metal.
Bramble told you: just sand it and spray it. It will always be better (even if you're clumsy) than peeled paint.
And if first shot isn't good enough, sand it and spray it again, it's just Bare metal, you're not cutting or carving it.
Even if the paint do wear quickly you'll be able to do it again when needed.
As long as you take care of protecting electronics which is quite easy, there's no problem in trying.
Hope this helps.
marexy
marexy replied on Wed, Feb 5 2020 12:52 PM
simple as can bee.
sand paper 200, car primer in spray, matt black car paint in spray...i done number of them with no problem.
JKW TAYLOR
Nederland
Thanks for the tips, I like the idea of using a primer to give it a key, is the car primer and paint, thinner based, white spirit or water ?
Ken
Page 1 of 1 (13 items) | RSS
