Masterlink Gateway Protocol - doesn't forward light command?
Not Answered This post has 0 verified answers | 15 Replies | 1 Follower
giac
giac posted on Fri, Jan 31 2020 4:24 PM
Hi there.
I have a Raspberry PI connected to a MLGW via the MLGW protocol (login on Ethernet from the RPi to the MLGW). Sending commands from the RPi to MLGW works fine, as well as the RPi receives "configuration change" messages, so the actual connection and protocol seems to be working.
However, it seems like the MLGW does not forward the Light commands from my NL units to the protocol connection.
I see the light command from my Network Link unit show up in the MLGW "Monitor" log (so the MLGW receives the light command), but the RPi never receives the command on the protocol connection.
How do I make the MLGW forward the light commands to the RPi?
I tried with macros, but there seems to be no way for a macro to send messages through the MLGW protocol connection.
Thanks!
Giovanni
frog
Camberley UK
frog replied on Thu, Feb 13 2020 7:25 PM
I’m getting Light packages into a raspberry (I’m connecting via port 9000) from a Beosystem 4, so something else must be happening here - if it is hitting the monitor, then the NL device is set up to forward MLGW messages correctly.
 What is the NL device you are using?
what is the code you are using to connect?
giac
giac replied on Fri, Feb 14 2020 6:22 AM
Interesting.
The device is a Beovision 55. They show up in the monitor, but not forwarded to the RPI over the 9000 port. Same thing for my Masterlink devices. Light commands show up in MLGW monitor but not forwarded.
I'm using a Hass.io python script to connect.
firmware of MLGW is 2.24. Wondering if there is some secret setting.
I worked around it by creating macros on the MLGW, activated by the light commands, but that push REST commands to the RPi to activate scenes. Works fine but it's not what I wanted!
Giovanni
giac
giac replied on Fri, Feb 14 2020 6:26 AM
this is the code: https://github.com/simonkamronn/mlgw/blob/master/bangolufsen/media_player.py
frog
Camberley UK
frog replied on Sun, Feb 16 2020 1:21 PM
Here's my code - which works with the Light command -
https://rapidgator.net/file/f97262f9dfabca44aae57c59c829ca1d/mlgw_client.py.html
Zeus_72
Hi Frog
I would like to study your program in python but the link you posted is no longer working. Could you share it again?   Could the program be adapted to work with home assistant?
giac
giac replied on Tue, Aug 25 2020 7:28 PM
There is code to run the bang Olufsen MLGW from Home Assistant here, which is maintained: https://github.com/simonkamronn/mlgw
Zeus_72
Thanks Giac
I saw the link you posted, but with the latest versions of home assistant it doesn't work well, at least on my raspberry. the script gives me a lot of problems and Lovelace B&O control card doesn't work at all. Although I don't have the skills, I wanted to study both Simon Kamronn's and Frog's scripts to understand if it was possible to modify them and make them work with my home assistant installation.
giac
giac replied on Tue, Aug 25 2020 8:53 PM
That's odd. It works fine with my home assistant. I'm on the latest version of HA. did you configure it correctly?
what is the error(s) you get?
Zeus_72
Hi Giac
maybe it is better that I tell you my configuration and then tell you the errors I have.
I installed home assistant core on a raspberry pi 4. the home assistant core is a little different from the iso hassio, and maybe this could be the problem.
The errors are:
- In B&O entity settings appears "This entity does not have a unique ID, therefore its settings cannot be managed from the UI".
- The home assistant interface does not report the status of the B&O device. I try to explain, if I turn on Beovision 7 from home assistant, the interface shows the status "on" and the TV turns on but if I turn off Beovision 7 from Beo4, the home assistant does not change the status to "off".
- I installed the plugin for lovelace UI but the media control I am going to create has the following error "Attemped to assign to readonly property"
thanks again for your time
P.S. se ho capito bene dovresti essere anche tu italiano. Se così fosse potremmo continuare la conversazione in questa nobile lingua Smile e spostarci nel forum a noi dedicato.
Grazie ancora dell’aiuto
giac
giac replied on Wed, Aug 26 2020 9:19 PM
Ciao,
I'd rather continue in English since it may be useful to others :-)
Masterlink devices unfortunately don't report when they are turned off to MLGW, so I haven't been able to make the return path work to update the status. I have the same issue with my Beosound 3000. Beosound only reports when some sources are activated (e.g. CD or RADIO are activated).
You should not need to install any plugin in Lovelace.
You only need to install __init__.py, manifest.json and media_player.py in the custom_components/bangolufsen directory, and a config entry in configuration.yaml, this is mine:
media_player:
  - platform: bangolufsen
    host: 192.168.1.10
    username: xxx
    password: xxx
    default_source: A.MEM
    available_sources:
      - A.MEM
      - CD
      - RADIO
    devices:
      - Living Room
      - Kitchen
      - Patio
      - Studio
      - TV Room
      - Bedroom
      - Bathroom
Then Lovelace should pick up the media player using the normal media_player UI element.
I use mini_media player as a UI element which is nicer.
https://github.com/kalkih/mini-media-player/blob/master/README.md
Zeus_72
Ciao Yes - thumbs up
ok we continue in English.
I would like to understand if you also have this error in the Beo entities: - "This Entity Does Not Have at Unique ID, Therefore Its Settings Cannot Be Managed From The UI".
Another thing I would like to understand is whether the communication limit between the mlgw and home assistant is the script or the mlgw protocol.
Reading the MLGW Protocol specifications Rev3 I noticed two types of payloads that report the status of the ml device.
The value 0x02 reports the status of the audio and video source including standby while the value 0x05 communicates that all the devices have been turned off. If so then the limit would be the script and it could be improved.
The plugin I was referring to is the javascrip program “beo-control.js” also written by Simon Kamronn. Have you tried it?
just one more thing Smile if you have Frog’s code could you share it?
giac
giac replied on Thu, Aug 27 2020 4:16 PM
1) I get that error too but it does not affect operation. Not all entities need a unique Id. you only need it if you want to persist settings which in this case we don't
2) it's a device thing. Some devices like don't implement the full protocol, ie they don't send a status change when they are turned off. the code actually is designed to handle the turn off packet if the device sends it. you can see exactly what is sent by devices by turning on "INFO" logging for your plugin and looking at the Home assistant logs.
3) you don't need beo-control.js, it's old code and doesn't work. You can just use the normal media player UI from Lovelace.
giac
frog's code
#!/usr/bin/python           # This is mlgw_client.py file
# It connects to a Bang & Olufsen Masterlink Gateway and interprets the LIGHT button pressed on a remote control
# It then connects via JSON to a Domoticz home automation server to switch on/off/dim a particular light
import socket               # Import socket module
import time     # Import Time module for delays & time
import datetime     # Import time of day module
import json                 # Import JSON to connect to Domoticz
import urllib
import urllib2
import os     # Import OS calls library
import __main__
import sys
__author__  = 'Nigel Smith'
__version__ = '0.1'
#Debug Flag
debug = True
sniff = True               # Sniff MLGW packets and display
# Setup B&O datagrams
serno = '01390000'.decode('hex')
#BV10Standby ='0101030012004700'.decode('hex')
#BV10AppleTV ='0101030012008500'.decode('hex')
#BV10Sky =    '0101030012008A00'.decode('hex')
#BV10off=     '0101030012000C00'.decode('hex')
#mlgw address
hostname = ("192.168.0.22")           # Masterlink Gateway hostname
#Rooms
Lounge = 1
Office = 2
Bedroom = 7
Dining = 4
Bathroom =5
Garden = 6
#Lights
RoomLight = 12
LoungeLight = 78
OfficeLight = [[12,False],[ 12, False], [15, False], [16, False]]
BlindLight = 194
VerandaLight = 17
BathroomLight = 45
GardenLight = 322
BedroomLight = 20
#Buttons
BOLightON = 155
BOLightOFF = 54
BOLightUP = 30
BOLightDN = 31
BOTV = 138
KeyRelease = 126
PanelOFF = 88
Exit = 127
Menu = 92
BOLightLeft = 50
BOLightRight = 52
BOGO = 53
BOSelect = 19
ButtonDict = {1:'One', 2:'Two', 3:'Three', 4:'Four', 5:'Five', 6:'Six', 7:'Seven', 8:'Eight', 9:'Nine', 0:'Zero',\
              30:'B&O Light UP', 31:'B&O Light Down', 50:'Left Arrow', 52:'Right Arrow', 54:'B&O Light OFF', \
              88:'Panel OFF', 92:'Menu', 126:'Key Release', 127:'Exit', 155:'B&O Light ON', 19:'Select'}
RoomDict = {1:'Lounge', 2:'Office', 8:'Bedroom', 4:'En-Suite Bathroom', 5:'Family Bathroom', 6:'Garden'}
#Times
on_time = datetime.time(17,30)
off_time = datetime.time(5,00)
grouplight = False
class switch(object):
   value = None
   def __new__(class_, value):
      class_.value = value
      return True
def case(*args):
      return any((arg == switch.value for arg in args))
def ByteToHex(byteStr):
   hex =[]
   for aChar in byteStr:
      hex.append("%02X " % ord(aChar))
   return ''.join(hex).strip()
def SetLight(Lmp, opt, dimlvl,groups):
   if (opt == 'dim'):
     LightCMD="http://192.168.0.52:8080/json.htm?type=command&param=switchlight&idx="+str(Lmp)+"&switchcmd=Set%20Level&level="+dimlvl
   else:
if groups:
     LightCMD="http://192.168.0.52:8080/json.htm?type=command&param=switchscene&idx="+str(Lmp)+"&switchcmd="+opt+"&level=0"
else:
     LightCMD="http://192.168.0.52:8080/json.htm?type=command&param=switchlight&idx="+str(Lmp)+"&switchcmd="+opt+"&level=0"
   if debug:
     print LightCMD
   return LightCMD
def GetMLGWStatus():
   MStatus =ByteToHex(s.recv(255))
   if debug or sniff:
      print time.strftime("%c"), '____', MStatus
   return MStatus
def isLightCommand(Mstatus):
   if (int(Mstatus[3:5],16) == 4):
      return True
   else:
      return False
def getRoom(Mstatus):
    return int(Mstatus[12:14],16)
def getLightButton(Mstatus):
    if int(Mstatus[3:5]) <> 5:
      buttonkey = int(Mstatus[18:20],16)
      if debug:
         if ButtonDict.has_key(buttonkey):
            print current_time,Mstatus, '--','The button',ButtonDict[buttonkey],'was pressed in the',RoomDict[getRoom(Mstatus)]
         else:
            print Mstatus, '--''Unknown Key', buttonkey
      return int(Mstatus[18:20],16)
    else:
      return 0
# First check to see if program is running - if so - exit
try:
    if len( os.popen( "ps -aef | grep -i "+sys.argv[0]+" | grep -v 'grep' | awk '{ print $3 }'" ).read().strip().split( '\n' ) ) > 1:
        print sys.argv[0],"already running"
        raise SystemExit(0)
except Exception, e:
        raise e
s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)         # Create a socket object
try:
   host = socket.gethostbyname(hostname) # Connect to Mlgw.local
   port = 9000                           # Connect to MLGW Port
   if debug:
      print "Connecting to: ",host, port
except socket.gaierror,err:
   print "cannot resolve hostname: ",hostname,err
s.connect((hostname, port))
s.send(serno)
print ' '
print 'MLGW to Domoticz gateway'
print 'V1.0 - Nigel Smith, 26 Mar 2014'
print 'MLGW Serial Number:      ____',s.recv(255)
print 'Waiting for MLGW'
FirstTime = True
while True:
  MLGWStat = GetMLGWStatus()
  current_time = datetime.datetime.now().time()
  ButtonPressed = getLightButton(MLGWStat)
  if (ButtonPressed >0):
   if debug:
     print current_time
   if (isLightCommand(MLGWStat) & ButtonDict.has_key(int(MLGWStat[18:20],16))):
      while switch (getRoom(MLGWStat)):
        if case(Lounge):
           Room = 'Lounge'
           RoomLight = LoungeLight
   grouplight = False
           break
        if case(Office):
           Room = 'Office'
           RoomLight = OfficeLight[0][0]
   grouplight = False
           break
        if case(Bedroom):
   RoomLight = BedroomLight
           Room = 'Bedroom'
           grouplight = True
   break
        if case(Garden):
           Room = 'Garden'
           RoomLight = GardenLight
           grouplight = False
           break
        if case(Bathroom):
           Room = 'Bathroom'
           RoomLight = BathroomLight
   grouplight = False
           break
      if debug:
         print 'Button', ButtonPressed, 'Room', Room, RoomLight
      while switch (ButtonPressed):
        if case(BOLightON, BOGO, BOSelect):
           if FirstTime == True:
              FirstTime = False
              Button = 'First'
              break
           else:
              Button = 'ON'
              if Room == 'Office':
                 OfficeLight[1][1] = True
              if Room == 'Bedroom' or Room == 'Garden':
                 urllib2.urlopen(SetLight(RoomLight,'On','32', grouplight)) #Switch (relay)
              else:
                 urllib2.urlopen(SetLight(RoomLight,'dim','32', grouplight)) #Max brightness
              break
        if case(BOLightOFF):
           Button = 'OFF'
           FirstTime = True
           if case(BOLightOFF) and Room == 'Office':
             urllib2.urlopen('http://192.168.0.52:8080/json.htm?type=command&param=switchscene&idx=6&switchcmd=Off')
             for n in range(len(OfficeLight)):
                OfficeLightNo - thumbs down[1] = False
             break
           if case(BOLightOFF) and (Room == 'Bathroom' or Room == 'Garden' or Room == 'Lounge' or Room == 'Bedroom'):
             urllib2.urlopen(SetLight(RoomLight, 'Off',0, grouplight))
             break
           break
        if case(1,2,3) and Room == 'Office':
           FirstTime = True
           RoomLight = OfficeLight[ButtonPressed][0]
           OfficeLight[ButtonPressed][1] = True
           break
        if case(4) and Room == 'Office':
           FirstTime = True
           urllib2.urlopen('http://192.168.0.52:8080/json.htm?type=command&param=switchscene&idx=6&switchcmd=On')
                OfficeLightNo - thumbs down[1] = True
           break
        if case(5,6,7,8,9,0) and Room == 'Office':
           break
        if case(50,52,92):
           break
        if case(1,2,3,4,5,6,7,8,9, 0) and Room == 'Lounge':
           FirstTime = True
           Button = str(int(round((9 - getLightButton(MLGWStat)+1) *3.2)))   #change value from 0-9 to 32 to 1 - Bright to dim
           urllib2.urlopen(SetLight(RoomLight,'dim',Button, grouplight))
           break
        if case(BOLightUP) and Room == 'Lounge':
           urllib2.urlopen(SetLight(VerandaLight,'On',0, grouplight))
           break
        if case(BOLightDN) and Room == 'Lounge':
           urllib2.urlopen(SetLight(VerandaLight,'Off',0, grouplight))
           break
        if case(BOLightUP) and Room == 'Office':
           FirstTime = True
           urllib2.urlopen(SetLight(BlindLight,'Off',0, grouplight))     #Toggle Blinds
           break
        if case(BOLightDN) and Room == 'Office':
           FirstTime = True
           urllib2.urlopen(SetLight(BlindLight,'On',0, grouplight))     #Toggle Blinds
           break
        if case(KeyRelease):
           Button = 'Key Release'
           break
        if case(PanelOFF):
           Button = 'PANEL OFF'
           break
        if case(Exit):
           Button = 'Exit'
           Looping = False
           break
      if debug:
           print '>>>', Button, 'pressed in ', Room
   else:
      if debug:
           print ''
s.close                     # Close the socket when done
Zeus_72
In summary, for lovelace I don't have to use beo-control.js and the "unique id" error is not relevant.
Only problem is that I don't get any feedback when I use beo4 not only when I put the device in standby but also when I change source.
I will check all the steps I have made and look for where the issue is hidden.
thanks again for all the help you gave me
Page 1 of 2 (16 items) 1 2 Next > | RSS
